6.3V 4A-5A filament transformer
EDY19, Thu Jun 08 2006, 01:26AM
I'm looking for a 4 or 5 amp filament transformer rated for 6.3VAC. Anyone have a spare or know where to find one? I don't want to rewind a MOT because the transformer only has to be rated for 25.2W, not 1000W
Thanks! Also the primary should 115VAC. If worse comes to worse, I may just find a 30VA transformer and wind a new secondary for 6.3V.
..., Thu Jun 08 2006, 02:39AM
I've got a few 12.6v CT (ie 6.3+6.3) 4a trannies... High potted to 2kv
pm me
Re: 6.3V 4A-5A filament transformer
EDY19, Thu Jun 08 2006, 02:57PM
Nevermind, I found a soldering iron transformer thats rated for 125W that should work great.
Edit: cant fit enough turns with thick wire... still looking for a core with more V per turn or an actual filament transformer
Dr. Drone, Thu Jun 08 2006, 08:57PM
EDY19, Fri Jun 09 2006, 12:40AM
I'd like to find one that has exactly the ratings I need- Picky, I know
but I don't want my VTTC to weigh a ton with a MOT and another oversized transformer. Thanks for the sites though, If I needed another transformer, I know where to go!
Electroholic, Fri Jun 09 2006, 01:40AM
mod computer smps?
EDY19, Fri Jun 09 2006, 01:57AM
That may not do well connected to a MOT
and its a bit too big.
Electroholic, Fri Jun 09 2006, 11:48AM
What I meant was,
increase the 5V rail on the smps to 6.3V
but yea, its probebly a bit overkill.
EDY19, Mon Jun 12 2006, 02:44AM
Im just going to use my homewound so I can add another tube filament to the circuit if I want- add one more turn and the voltage stays at 6.3 with 2 tubes- the secondary is wound with 12 or 14 wire i think, so 8A total should be fine.
