It lives! WOOT!
Part Scavenger, Wed May 31 2006, 02:12AM
My DRSSTC is alive after many weeks of waiting! My dad told me I had to clean up all my crap before I could do anything else. I've been working on that for about 2 mo. Sheesh, but it looks great. I'm glad it did it.
The saturday before memorial day, I was back into action. I spent the afternoon of memorial day building a new primary and running scantesla stuff. Scantesla suggested a coupling of .185 and primary at 10.5 turns. 10.5 seemed a little high to me, but oh well. I tried it anyway.
After doing all that, I tried it out. To my chagrin, it performed no better than it did before. After poking about some more, I realized that I had soldered the primary tank capacitors improperly making the primary resonate MUCH lower than the secondary... Too late, time for bed.
Next morning (this morning). Fixed the capacitors and right away got longer sparks. My OCD is still acting up! Cutting out at 50A and not allowing adjustment. One of the pins on a 555 in the circuit had a cold weld on the ground. When you pushed on it with the meter, it tested fine, but when you let off, it disconnected itself. What a booger it was to find! Then after fixing that, I
The FGA cheapos suck, the International Rectifier's GRP-somethings are great. So are these obscure Fairchild ones that I'm using right now. I'll post part #'s on my site soon.
FGA's croak, and like a moron, I had forgotten to add a fuse and my variac craters
Not good, but it repairs. 5 min later, I realize the fuse blew in my 'scope at the same time and I don't have another. Worries me why the fuse blew...?
I've still got problems with my OCD, it won't fire at all now, even after checking all components and replacing chips. Hmm. Any ideas? The output of the comparator stays high the whole time. I was going to scope it, but see above.
BTW, I got 22" and the groundstrike with the screwed up OCD killed my IGBTs.
Since I lost my scope about 2:00, I've been slowly increasing the power and recording data on the safe side. The new Fairchilds are holding up great. I'm getting 12" streamers with 360W. I should be getting lots better, but I'm working on it. Then I dropped my interrupter and knocked the ground wire loose. After repairing it, I ran it with the case open. Doing so I touched the back of the interrupter board, and...
HOLY SMOKES! *Jumps back in terror*
Apparently, I touched off a really long pulse. Then, I did it over and over for fun!
Boy I wish I could see this on the 'scope. It must not be too hard on my IGBTs as I can do it for long(ish) periods of time.
Enjoy the videos, the first one's great! Looks like Steve's "long pulse" thread. Note, I'm not running the coil properly here...
EDIT=> Hmm. No vids. Hang on...
Re: It lives! WOOT!
Part Scavenger, Wed May 31 2006, 02:22AM
Re-posting of video
Crap. That didn't work either.
I'll upload them to my site.
It lives! WOOT!
..., Wed May 31 2006, 02:45AM
if they are under 10mb then they are probably not a supported format, so just zip them up (I think windows does that nativley now) then upload
Sounds fun, are you using an isolation transformer? If not the reason you blew the fuse in your scope is that you were trying to ground every half wave of the incoming AC through the ground clip of the scope...
Patiently awaiting videos...
It lives! WOOT!
Part Scavenger, Wed May 31 2006, 02:56AM
Re: It lives! WOOT!
Desmogod, Wed May 31 2006, 04:13AM
That first video looks very SSTC like....
What PW are you running?
Re: It lives! WOOT!
Hazmatt_(The Underdog), Wed May 31 2006, 08:02AM
Wow I gotta get me one!
It lives! WOOT!
Marko, Wed May 31 2006, 09:10AM
W007. I think DRSSTC will inhreit the world...
It looks nice, only thing I see is that you had pretty high primary-secondary coupling, this probably limits the peak current but it may easily arc over. (if you didn't change the primary in meantime
Good luck (and long sparks)
It lives! WOOT!
Part Scavenger, Wed May 31 2006, 01:19PM
Yeah, I was using a CT to scope the primary current waveform. That's why I don't know why the fuse blew.
I really like the big arcs, they've got a deep throaty sound not captured well by the video. I think I might build this mode into an interrupter. The IGBTs are doing fine, today I'll go to rat shack on my lunch hour to fix my scope. Then I'll check out the waveforms and post.
It lives! WOOT!
Avalanche, Wed May 31 2006, 01:29PM
I love that first video, sounds good too. I take it the OCD just keeps tripping to get the low BPS?
I think coils look more impressive running like that, but that's just me
It lives! WOOT!
Part Scavenger, Wed May 31 2006, 07:03PM
Avalanche wrote ...
No, that's me jabbing my thumb into the bottom of the interrupter.
It only works with in about 4' of the coil though...
The OCD is not even triggering
I really wonder why nothing blew up doing this.
Re: It lives! WOOT!
williamn, Thu Jun 01 2006, 01:42AM
Very cool video. Those streamers look like you have extremley high on times, do you know what they are?
It lives! WOOT!
Part Scavenger, Thu Jun 01 2006, 10:07AM
Sadly, no. I put my interrupter back together before I got my oscilloscope working again. Attached is a wimpy picture from the other day, I'm getting 27" to the ceiling now! But, I never took any pictures.
Note the florescent isn't actually on...
It lives! WOOT!
Vaxian, Wed Apr 11 2007, 08:26AM
Love your screen name, and the coil also.
Love the step by step on your website, hope you don't mind if I borrow your primary method for my next coil, very neat.
Too bad about your scope, and that poor airplane!
Dan
