ZVS Video
Adam Munich, Sun Dec 26 2010, 07:44PM
Finally got around to making one.
ZVS Video
Myke, Sun Dec 26 2010, 09:16PM
You shouldn't even be holding the "ground" wire in the video... It may be sitting at a couple kV higher than the ZVS circuit due to leakage currents and such...
Always use a chicken stick
Re: ZVS Video
Wyatt, Sun Dec 26 2010, 10:01PM
Nice.Very nice.
Re: ZVS Video
quicksilver, Sun Dec 26 2010, 10:26PM
You know, I really like the way you display your schematics on your pages. It's clean, neat and useful for a discussion. I've said this before but I notice now that you have made that type of illustration a "style" in your site. Frankly I really like it.
Re: ZVS Video
Adam Munich, Sun Dec 26 2010, 11:44PM
I did it to help the n00bs. I think it's the most simple way to display things.
I'm also not holding the ground electrode, I'm holding the rubberized clip lead below it; my hand blocks the view.
Just noticed a lot of typos. Fix'd.
Re: ZVS Video
Ash Small, Mon Dec 27 2010, 01:16AM
A picture tells a thousand words. Impressive schematics, Grenadier.
One point, and I'm probably wrong here, but I've been reading a bit on zero current switching and zero voltage switching on other sites, and I'd got the impression that the 'zero switching' concerned the transformer rather than the transistor(s).
I was under the impression, specifically, that if the transformer was switched when the current was zero, there would be no field to collapse, therefore no (in theory) transient voltages or wasted energy.
I was also (and I may well be mistaken here) under the impression that the discussion between zero voltage switching and zero current switching was something to do with phase lags, etc.
Some of this was read in the context of using current transformers controlling phase locked loops to control transistors via feedback.
Coming back to my original point, I was under the impression that the trick in a zero voltage switching circuit was to switch the transistor at a point when the voltage in the transformer was zero. Am I getting confused with something else?
(If you don't ask, you don't learn.)
EDIT: I think, specifically, that if the voltage across the primary is zero, the current, lagging by 90 degrees, is at a maximun, and that if it is switched at that point, the maximum amount of energy is delivered to the secondary, thereby producing a very efficient transformer.
This is what I thought ZVS meant.
Re: ZVS Video
Adam Munich, Mon Dec 27 2010, 01:24AM
I'm not certain myself. Anyone want to clear this up?
ZVS Video
Ash Small, Mon Dec 27 2010, 03:17AM
I found this:
Not read it all yet, but from what I've read so far, it appears we may both be correct.
EDIT: It seems to say you switch it when the voltage at the drain is zero. I think this means the voltage across the primary is also zero.
Maybe someone else can clarify things here?
EDIT: also found this, mostly about buck converters, but I think it suggests I'm wrong and Grenadier is correct.
and this, from wikipedia:
"Quasi-resonant zero-current/zero-voltage switch
Quasi-resonant switching switches when the voltage is at a minimum and a valley is detectedA quasi-resonant zero-current/zero-voltage switch (ZCS/ZVS) where "each switch cycle delivers a quantized 'packet' of energy to the converter output, and switch turn-on and turn-off occurs at zero current and voltage, resulting in an essentially lossless switch."[13] Quasi-resonant switching, also known as valley switching, reduces EMI in the power supply by two methods:
1.By switching the bipolar switch when the voltage is at a minimum (in the valley) to minimize the hard switching effect that causes EMI.
2.By switching when a valley is detected, rather than at a fixed frequency, introduces a natural frequency jitter that spreads the RF emissions spectrum and reduces overall EMI."
Re: ZVS Video
Steve Conner, Mon Dec 27 2010, 02:00PM
ZVS means that the transistors switch after the voltage across them has been brought to zero by some other method. ZCS means likewise for current.
Either one reduces switching losses in the transistors quite a bit. I don't think it reduces losses in the magnetics. Although, in the Mazzilli circuit that you guys call "The ZVS", the tank capacitor recycles energy that would otherwise be lost through leakage inductance between the half primaries.
ZVS Video
HVPaul, Mon Dec 27 2010, 10:04PM
Is that point to point construction?
Would you kindly post the the reverse side of the board?
Thanks
Grenadier wrote ...
Re: ZVS Video
quicksilver, Mon Dec 27 2010, 10:13PM
Blow up his pic: his leads ("traces") appear to be straight felt pen lines to his pin-outs. . It's a good enough pic so when you blow it up you can see the leads to the pin-outs drawn clearly. It's rather cute. I think it one of the more concise ones I've seen. Unless I have it all wrong and the reverse much more overlap than the felt-tip pen lines.
ZVS Video
Adam Munich, Mon Dec 27 2010, 10:31PM
Here's the bottom of the board. I forgot to put this pic on the page.
I used a dremel to cut out the copper I didn't need, then I thickened the traces with solder. I then colored it with marker because I was bored. I designed the board on the fly as I always do. Somehow it usually works out.
Oh, that shiny stuff isn't flux, it's water. I used snow as a background for the last photo.
ZVS Video
quicksilver, Mon Dec 27 2010, 10:47PM
I don't remember who did this one but it may be the best point to point I can remember for a Mazelli driver.
There is a certain imaging skill that just seems to be a gift with some folks. I sure haven't got it.
Re: ZVS Video
Adam Munich, Mon Dec 27 2010, 10:57PM
I'm very good with point to point, it's just a matter of finding a suitable base to keep it all steady. Point to point things just look so cool IMO, kind of like an art.
ZVS Video
radhoo, Mon Dec 27 2010, 11:15PM
ZVS Video
Myke, Tue Dec 28 2010, 01:23AM
quicksilver wrote ...
Hahaha. That's my driver I made a while ago.
Thank you for the compliment.
ZVS Video
quicksilver, Tue Dec 28 2010, 04:25PM
Well Myke, I don't want to be obsequious however let me say that I have used your model since I saw it! I just don't have the chops for what seems almost like "puzzle art". There were a great many things to consider in such a point to point size reduction.
I have a friend who actually does have some EE education (I have none) & I showed him (both pics of yours) & HE said "the guy is gifted" when I told him I was pirating the design.
My old buddy was the guy who actually explained how the Mazelli functioned in it's relationship to both frequency alteration and why it was a better choice design than others I had played with. The first thing he noticed (in the design) was that the significant components were brought together with higher current in mind: short, thick, stout connections, etc. Muy' suave, senior.
Thinking this over realistically, all the people who have made quality examples of this driver started with a decent heat-sink. IMO - if a person can get a hold of a heat-sink that will hold both MOSFETS; the wiring CAN be simplified better and better the more you build them! Perhaps one of the nicest schematics are on Grenadier's site. extrapolating from that I think that if one were to build one with some fore-thought - that particular item may just be a serious help to making a unit that not only lasts and works well but is something to be proud of.
One thing that has helped me was to put the schematic in a graphics program environment and shortening the traces. Certainly there are those folks that can build them right out of their head but if you're like me & don't have that gift......well - copying is the most sincerest form of flattery.
