What to do with an old CRT
Maz, Sun May 28 2006, 02:52PM
I currently have an old crt sitting in the middle of my bedroom, on the floor. i need to do something cool with it so i can justify getting rid of it (it still works). what shoild i do with it?
Tesladownunder, Sun May 28 2006, 04:30PM
1: Make a
spinthariscope with the CRT phosphor. Also need a magnifying lens or eyepeice and the alpha emitter from an old smoke detector.
2 Make a vacuum chamber as in
Jochens vacuum page.
3 Make a lifter supply (if you have the whole monitor with functioning HV).
4 Strip it of useful parts like the flyback, capacitors, mains cord, speaker or whatever but release the vacuum first by breaking off the pointed tip first under a cloth.
Peter
Re: What to do with an old CRT
Hazmatt_(The Underdog), Sun May 28 2006, 06:00PM
Because you want to use the tube:
1. Make a cool CRT clock like the ones made from Oscilliscope tubes
2. Make an oscilliscope
3. HEHE Make Pong
4. Make a cool Lissajou demonstration for kids to teach them about frequency division, harmonics, and all the cool old information that is now lost or burried.
I would love to do this with 2 lasers and make a laser light Lissajou show for the science center on campus. We would also incorporate sound as a fundamental of a concert A so the kids can hear how frequency, sound, and light all relate to one another. I think its a real hard-core demonstration of principles and understandable at the same time.
Maz, Sun May 28 2006, 10:33PM
now how would i be able to make an oscilloscope?
Hazmatt_(The Underdog), Mon May 29 2006, 08:45AM
how is a different thread
Bored Chemist, Mon May 29 2006, 08:47AM
"Make Pong"
I thought that was chemistry.
A 'scope would be quite tricky because these things are designed for magnetic deflection. The frequency response would probably be rather limited.
Alfons, Mon May 29 2006, 03:06PM
Maz wrote ...
Watch
and
for instructions how to turn a television in a scope... maybe you'll find some inspiration there
Tesladownunder, Mon May 29 2006, 03:47PM
At least I have done 3 out of 4 of my suggestions. Who has made an oscilloscope, PONG or a Clock (without using the CRT as a simple computer monitor)? Hands up please
I may need to use the electron gun out of one as my electron gun out of my x-ray tube may be too big for the standard glassware.
Peter
Philcogrump, Tue May 30 2006, 02:42AM
I raise my hand for all three...
Bored Chemist wrote ...
No, actually, I think you have it in reverse. Almost all oscilloscopes use electrostatic deflection, not magnetic deflection. Electrostatic deflection has much faster response than magnetic deflection, which is why it is used for many oscilloscopes and at higher frequencies. Magnetic deflection has its limitations at certain frequencies. I built a simple scope using a 2AP1 CRT and three tubes. I also even have a commercial scope from the 40s that only had the CRT and one tube. These things are EASY to build methinks.
What kind of CRT do you have, Maz?
..., Tue May 30 2006, 03:48AM
Umm, I believe you misread the post...
the tube from his computer monitor (implied in the first post) uses magnetic deflection, which makes it poorly suited as a scope.
I would just strip it for parts, or combine it with an old junker computer and give it to a relative for their b-day, or if you are lucky you can donate it to the salvation army or local thrift store, then write it off on your taxes for like $50, then get 2/3 of it back
Bored Chemist, Tue May 30 2006, 08:02AM
"Umm, I believe you misread the post..."
Yes, he did.
I like the idea of writing it off against taxes.
Self Defenestrate, Tue May 30 2006, 01:48PM
Haven't tryed it myself, but looked cool.
The CRT Vacuum Pump
Billybobjoe, Wed May 31 2006, 12:36AM
Would it be possible to make a weak X ray tube from one? The thick lead glass on the front may stop a bit but if you upped the voltage I bet you could get a decent amount from the front of a small one with thinner glass.
Philcogrump, Wed May 31 2006, 03:55PM
Maz wrote ...
I don't see any implication that the CRT came from a computer monitor. I naturally assumed "old" CRT meant like a real oscilloscope CRT.
Well, anyway, if it was that kind of CRT, then sadly I'd suggest using it for target practice.
Bored Chemist, Wed May 31 2006, 05:57PM
Roughly what fraction of the worlds CTRs come from 'scopes rather than TVs or computer monitors?
Steve Conner, Wed May 31 2006, 08:35PM
2/3, in my house at least.
..., Wed May 31 2006, 10:14PM
As far as how many produced, I would say about 99.9% of tubes are electromagnetic... (computer monitor or tv) Although that number will drop now that lcd's are becoming more popular...
Bored Chemist, Thu Jun 01 2006, 06:14PM
"2/3, in my house at least."
OK, so it's 3/5 in my house (and an interesting question if I am using my computer monitor as a 'scope), but I don't think that's very representative of the world.
Anyway, the most fun I had with an old CRT was throwing a brick through it, but I wouldn't recommend doing this in a bedroom.
Bjørn, Fri Jun 02 2006, 04:35AM
Philcogrump is correct in that the first post does sound like it is a bare CRT. Just by looking at the post my guess was that he was talking about a computer monitor. Who puts a CRT in the middle of the floor and how does he know that it is working? In addition he cuts corners with capitalization and spelling so he would use "CRT" instead of a more correct and longer phrase.
I find CRTs to be rather boring. The only thing I have used one for is to store shadows of scary events using a flash. Now that digital cameras are everywhere it would not make sense anymore.
Maz, Sat Jun 03 2006, 01:44AM
I know it still works because i have tried it. I did not capitalize CRT on accident before. And, if anyone wants anything off of it, just PM me because other than sitting in my room, it is doing nothing. Bjorn, you sounded condescending, there is no reason for it, and no reason for you to be edgy towards me. Assumptions were made on all parties.
"In addition he cuts corners with capitalization and spelling so he would use "CRT" instead of a more correct and longer phrase."
But it still doesnt make a difference, a crt is a CRT. I know you are a mod, and I dont really care. If you do not have anything to contribute to the thread, please do not post.
Everyone else,
thank you for your help.
Bjørn, Sat Jun 03 2006, 07:03AM
You still have not made it clear if you have a cathode-ray tube or a computer monitor in the middle of your room. Since you don't protest when people assume it is a computer monitor I conclude that in this case a CRT is not a CRT but a CRT monitor.
The use of third-person in my previous post made it sound more condescending than it was meant. Any edge was entirely on purpose and caused by lack of care on your part. If you had cleared up the confusion after the second post instead of letting it run for almost 20 posts it would not have been needed.
Maz, Sat Jun 03 2006, 02:48PM
CRT monitor bjorn.
