Detection of Zinc
tecNik, Thu May 25 2006, 11:25AM
Can anyone help? I'm looking for an easy way of detecting zinc from a leaking battery. I'm pretty sure I have had a battery leak that has destroyed a walkman but want to make sure that it was the battery. The nylon pull tag to remove the batteries has become hard and brittle. Any ideas on how to detect zinc without complicated processes?
Thanks
Re: Detection of Zinc
Electroholic, Thu May 25 2006, 03:59PM
assuming its a normal zinc carbon cell,
the "Juice" will contain more than zinc ions.
And i think Cl ions would be a lot easer to detect.
Get a solution of the "Juice", mix it with some silver nitrate .
if there is Cl ions, you will see white ppt. of AgCl.
hope this helps?
Bored Chemist, Thu May 25 2006, 08:18PM
There aren't any nice simple colour tests for Zn.
If you can wash enough of it into some water you could do some tests on it. the most characteistic thing is that the oxide turns yellow on heating but becomes white again when it cools.
Are you just hoping to prove that it's the battery's fault?
Bjørn, Fri May 26 2006, 05:34AM
I just touch the suspected leak and then touch my tongue, the evidence is usually quite overwhelming.
