  • Guests: 26
Alfons (36)
Coronafix (51)
AmonRa (44)
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Next topic »
A working model of a electromagnetic mass accelerator of high power
first  5 6 7 8
V2006
Tue Jun 28 2022, 10:28AM
V2006 Registered Member #61550 Joined: Thu Apr 06 2017, 03:23PM
New!
Apocalypse Coilgun, Fallout Coilgun - (COIL 2.5MM DIAMETER WIRE + 2x2.5 mm)
CAPACITORS 350 Volt, 34000 mkF (~ 2000 J)
BATTERIES 18650 + INVERTER 12/220 VOLTS
In the 21st century, if you dig in a landfill, you will find parts for assembling coil guns faster than parts for a crossbow or bow))
Look here:
Coilgun - it's weapon apocalypse?
Fri Jul 01 2022, 05:07PM
Fancy looking gun you got there. :)
V2006
Tue Jul 05 2022, 08:58AM
klugesmith wrote ...
Of course. Apocalypse in the yard :))
V2006
Fri Mar 17 2023, 12:11PM
Hi evreone.
At present, the efficiency of acceleration of metal projectiles by a magnetic field is inferior to the efficiency of acceleration of metal projectiles due to the expansion of powder gases. And, it is possible that due to the imperfection of the technologies for manufacturing electricity storage devices, this situation will continue for a long time.
But! The above is true (primarily) for the acceleration of small-caliber projectiles (bullets used in individual small arms).
And to implement the acceleration of more massive projectiles (for example, shells of grenade launchers and rocket-propelled grenade launchers), a magnetic field can already be used with great efficiency today.
!The evolution of the bazooka in the third millennium
SILENT BAZOOKA (COILGUN - BAZOOKA).
Capacitor energy 2000 J, voltage 100 Volts.
In this experiment, instead of a cumulative or fragmentation grenade, a 0.87 inch (22 millimeters) steel scrap weighing 1.32 pounds (0.6 kilograms) was used as a projectile accelerated by a magnetic field.
*there are no factors unmasking the position of the shooter
V2006
Sun Aug 27 2023, 07:44AM
Hi everyone.
Breaking news! Coilgun of the future - artillery
Or is the artillery of the future a coilgun?
See also:
Ultra Home made Coilgun (caliber one inch, projectile weight two pounds)
Super Power full Coilgun (caliber 0.87 inch, projectile weight 1.32 pounds)
first  5 6 7 8
