trying to repair FRG-7 receiver
Registered Member #543
OK.
Now measure accurately frequency across whole tuning range, and post results here, so we can talk about them.
You may also find this FRG-7 restoration project helpful:
caffel
Registered Member #65348
FRG-7 tuning. Thanks for this exceptional guidance. As I start the tune up of my own FRG-7 I see an ambiguous instruction on page 11 of the manual "Set the band switch to A and the MHz dial to 0. Disconnect the antenna and connect its output to antenna terminal." If this makes sense to you, could you explain with a few more words ? Thanks, caffel
Registered Member #96
Would a frequency counter be any use?
