  • Guests: 81
Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
05/30 Quantum Singularity (46)
isolated gate drives
first  3 4 5 6
ragnar
Fri Jun 30 2006, 02:41AM
The fuzzy wavey noise disappears when I grab just about any component, including the scope's ground lead, so we'll see what happens.
Fri Jun 30 2006, 04:47AM
You are coupling noise through the drains of each fet to the heatsink. You should find out how to remedy this before you cause your gate drivers to overheat! This is the common mode noise Conner mentioned. Luckily, my big IGBT brick drives dont seem to suffer from this despite not even considering the problem when i designed them.
If those are real you have serous problems
Not really... high dissipation is to be expected at 2.4mhz with common fets. If he is careful about zero current switching with his load, then he should be fine.
Fri Jun 30 2006, 09:47AM
That fuzzy ringy stuff looks like some sort of parasitic oscillation. If it were just ringing excited by the gate drive edges, it would have a decaying envelope. Anyway the acid test is when you connect those FETs to some power and see if the waveforms still look nice when everything is di/dt'ing and dv/dt'ing all over the place like crazy.
Good luck trying to get a low enough inductance layout to work at 2MHz, with your FETs in a row tongue
ragnar
Fri Jun 30 2006, 11:29AM
heheh, that wasn't just for photo mockup, but to test the drivers all at once (and consider switching a few volts through a resistor)... =P
I should have posted the pic of solid aluminium stock I'm using for separate heatsinks...
..hehe, now, how to have a low-inductance layout, but not have the plates parallel next to each other, forming an air capacitor... ^^
first  3 4 5 6
