Registered Member #1938
Hi Proud Mary,
it proved useful so far for quickly testing the new tubes for the more obvious defects, however I regret the way I designed it - to collect the signal from the cathode . At the time I made the board, I didn't think of the external connector, it was added later.
Back to the SI29BG, it features a rather interesting anode. I found a few pics of a dismantled tube:
I wonder if the strange anode might have anything to do with the good performance of this tube, at least when compared to the larger SBM-20.
Registered Member #543
radhoo wrote ...
Hi Proud Mary,
I remember that some Russian tubes were also designed to work in proportional mode, at a voltage slightly lower than the bend up onto the GM-region plateau - 10V - 20V less. I wonder if this could be one of these? The thicker anode would have been less susceptible to microphony and changes in C caused by the vibration or acceleration compared with a fine wire.
In normal GM use, the finer the wire, the better it is, so there must have been some reason for it, though I guess the fact that it is only supported at one end is part of the reason.
On the Russian data sheet, what is the parameter between 250V and 340V - the second line in the parameters table?
You are probably right about the thick anode and having support at only one end. Still, vibrations can be solved even with a smaller anode section diameter. Also that black powder looks intriguing.
wrote ... On the Russian data sheet, what is the parameter between 250V and 340V - the second line in the parameters table?
I believe it translates as : "Initial voltage (volts)"
radhoo wrote ...
That's what Centronic call the 'starting voltage' - needed to estimate the output pulse amplitude.
I completed a variant of the Model A for SI29BG geiger tubes, that will be distributed with the one using SBM-20U tubes. Next is the uRADMonitor model B, featuring an LCD screen to also allow offline use as a dosimeter, and a battery pack, but that's going to happen in 2014. Until then, I wish you all a Happy new year!
Registered Member #1956
I made a Nixie Clock with nRF24 transceiver. I have two temperature/humidity probes that can comunicate with it. To show the external and internal temperatures on my apt from 7 to 8AM, when it matters most.
It would be nice if I could display average and max radioactivity at night, say 9 to 10PM :)
I believe i2c, SPI or Serial would be great. You can set it Master Output only, in the case of SPI and have a stream every second containing time, max for last 24h, min last 24h, average 24h and current readings.
For the models that have no display that would also be great for troubleshooting as you can include other important info on the stream, NMEA style. One can just read it...
