Registered Member #2431
Pinky's Brain wrote ...
AFAICS the snubber transfers the energy from the primary leakage induction to the snubber capacitor when the MOSFET turns off (it doesn't keep ringing of course, I was wrong about that). When the MOSFET turns on the capacitor starts a partial oscillation with the inductor, initially the voltage at the right side of the capacitor will be negative, when it rings up with the inductor they can dump energy in the main power supply smoothing capacitor (ie. regeneration).
excellent, ill try to simulate all this then, ZVS and ZCS are what im trying to use to ease the burden on my square wave switching MOSFET/PPCT transformers too.
Registered Member #2901
You sure you want the headaches of ZVS/ZCS? The control schemes are not fixed frequency, and the standard ICs for them schemes aren't designed for transformers as lousy as high voltage transformers.
One way to reduce stress on the MOSFET is two switch flyback, Jan Martis's design is very elegant but to work it has to increase Vds above the power supply voltage. With a two switch design you can keep Vds at the same value as your power supply voltage.
when i say ZCS/ZVS i mean making sure the voltage and curretn arnt present at the same time while the switching transsistions are occurring. i absolutley dont want to get into sine wave stuff.
I am trying to do the math on a current transformer, id like to use a single wire pass through for the primary (as i see many of you SSTC'ers do with your bridges) so do i consider this kind of primary a 1/2 turn?
ive been reading the TI/Unitrode stuff here -> but it doesnt say in this case.
im trying for a 40kHz, single switch forward waveform current detection.
What EXACTLY do you mean with soft switching? I thought you merely meant slow switching since you want to avoid resonance.
AFAICS this isn't what your reference means when it says soft switching, it means using something like a resonant snubber or active circuit to achieve ZVS ... evil sine waves.
I want to use soft switching to reduce MOSFET heating. When i say ZVS/ZVC i dont mean a resonant circuit. I mean the voltage and current are not present at the same time, first one rises then the other, or first one falls then the other, having both V and I cross while the resistance is in the "linear" state it where most transistor heating comes from.
The switching times should change from off to on in the shortest time period possible.
