  • Guests: 21
Dalus (34)
Kizmo (37)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
SSTC questions
first  2 3 4 5
Bauerb2
Sun Oct 07 2007, 04:21PM
Bauerb2 Registered Member #973 Joined: Tue Aug 28 2007, 07:32PM
my half bridge flyback driver had those problems too. i had to make sure i turned on the driver circuitry before the bridge voltage was applied. If not the mosfets were ruined...
do these toroids look good for gdt use? Link2
it was funny because i googled ferrite toroids and got this site, which was based in pittsburgh PA, only 20 miles from my house. hah
Dr. H.
Sun Oct 07 2007, 05:28PM
Hi Bauerb2. I think that toroids will do the job, but let some of the more experienced member tell theyr opinion too. For the blowing tranzistors i was also thinking about the same cause. I was thinking to use steve's sstc1 soft start circuit. I holp that he will give some information why this is happening ???
Bauerb2
Mon Oct 08 2007, 08:03PM
after some research i found the W material ferrite toroid i linked to above wont do very well at 330kHz. So i stepped down to the J material (also called 75?). Link2 it is practically the smae thing, but diff material and perm. rating. i think it will suit well for 330kHz.
im still not sure how to order parts from Magnetics® though.... Link2
good luck all
-Andrew
first  2 3 4 5
