  • Guests: 26
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
X-Rays in small microwave bulb?
first  2 3 4 5
Uspring
Wed Nov 23 2016, 11:16AM
klugesmith wrote:
Mean free path for electrons is much greater than that for air molecules, at the same pressure.
Yep, about a factor of 5 for 100eV electrons. Got this from the "internet" and not from my own education as well as the statement, that todays light bulbs are gas filled frown
Physikfan
Wed Nov 23 2016, 12:49PM
I found an interesting paper on gas discharge in the internet:
https://mysite.du.edu/~jcalvert/phys/dischg.htm
http://www.physics.csbsju.edu/370/jcalvert/dischg.htm.html
The mean free path of electrons in a gas is also discussed as well as
1. voltage-current characteristics
2. sparks
3. glow discharges
4. arcs
Also:
http://www3.nd.edu/~sst/teaching/AME60637/notes/Go_ions_v4_031912.pdf
Physikfan
Sat Apr 08 2017, 05:09PM
Hi Klugesmith
"Physicsfan, are you equipped to extend Po's x-ray experiment using a high-vacuum pump and pressure gauge?"
Now I got a vacuum pump and a pressure gauge to do an experiment with a very old selfmade cold cathode discharge tube at different low pressures and at different voltages (different electron energies).
But still I have a problem.
Last time many years ago when I did this experiment the high voltage at the discharge tube destroyed my low pressure sensor.
I could switch on the pump and also the pressure gauge to get a certain pressure inside the discharge tube.
But before switching on the high voltage I should remove the pressure sensor from the equipment to be able to use this device a second time.
Or anybody has some hints for me to keep the pressure sensor alive when connected to the discharge tube?
Mon Apr 10 2017, 11:58AM
I'd like to point out that the radiographs mentioned above that I've made using very soft rays have been of subjects like flies' wings and microscopic plant sections.
Also: remember that the energy-response curve of uncompensated GM tubes is wildly distorted in the way of massive non-linear overcounting below about 75 keV. It wouldn't be unusual for a GM tube to over-count by a factor of twenty times and more when exposed to X-rays of 25 keV or so. This is because the counting efficiency increases in a non-linear way as more of the low energy photons are stopped in the counting gas.
first  2 3 4 5
