  • Guests: 41
GODSFUSION (37)
Zajcek (37)
ElectroDog (33)
sportcoupe (56)
04/30 BlakFyre (36)
04/30 SENTRY (31)
05/01 Shaun (34)
** Add your Tesla coil here **
Tesladownunder
Sun Feb 05 2006, 02:25AM
EastVoltResearch Oct 1 2004
Attachment 2: DRSSTC 1 Arc Picture
Evr Drsstc1 03
Tesladownunder
Sun Feb 05 2006, 02:27AM
Vasil Oct 1 2004
Ignition coils powred tesla coil
PSU: dual ignition coil system with secondaries in serie driven by a 1000 watts dimmer and 6 uF cap
primary: archymedical spiral, 14 turns, tap at 12 turns
primary cap: 1.33 nF @ 10 kV
secondary: 1.6" / 8", 800 turns
topload: 2.2" diameter light bulb covered in alu foil
sparks: 3-4 inches
More information here:
Ntc15
Tesladownunder
Tue Feb 07 2006, 04:34PM
Vasil Oct 1 2004
the same
1139330051 10 FT14 Ntc11
Tesladownunder
Tue Feb 07 2006, 04:38PM
Vasil Oct 2 2004
Mini ISSTC setup
- antenna feedback driver (74HC14>>UCCs>>gdt), with noise generator with 555 and 555 staccato interrupter (the same as described on Steve Ward site).
-IRFP260 half bridge, 470 uF@400 V DC cap, 120 vac full rectifyed input
-secondary: 11 cm / 30 cm, 400 kHz
-primary: 3 turns wound directly on the bottom of the secondary
-sparks: 8 inches
1139330326 10 FT14 Isstcpic1
Tesladownunder
Tue Feb 07 2006, 04:40PM
Vasil Oct 2 2004
EL509 VTTC
-El 509 pentode from the TV final stage
-primary: 4.33"/7.48", 22 turns, taped at 18 turns
-feedback coil: 19 turns above the primary
-secondary: 2"/18.89", 2500 turns
-sparks: 7-8 inches
1139330401 10 FT14 El57
Tesladownunder
Tue Feb 07 2006, 04:41PM
Vasil Oct 2 2004
miniDRSSTC
-phase locked loop driver, antenna feedback, non pulsed (developped by Steve Conner)
-IRFP260N half bridge, 120 vac half rectifyed
-primary: 10 turns on a 17 cm diameter flower pot
-primary cap: 15 nF @ 4kV ceramic
-secondary: 11 cm/28 cm, 966 turns
-topload: 3.4"/10.8" toroid
-sparks: 10 inches
1139330476 10 FT14 Z4
Tesladownunder
Tue Feb 07 2006, 04:42PM
Vasil Oct 2 2004
Spark gap tesla coil
PSU: 600 VA potential transformer ballasted with two 1 kW waterheaters in parallel.
no safety gap, no filters
secondary: 3"/9.6", 960 turns, 18.93 mH, 4.014 pF
toroid: 3.4"/10.8", 11.77 pF
res freq: 322 kHz
primary: flat primary, 14 turns, taped at 10 turns, 15.16 uH
primary cap: glass window covered with alu foil, for a total capacitance =16 nF: now I am using a 20 nF @ 16 kV MMC
sucker gap
sparks: 2 feet
1139330523 10 FT14 13
Tesladownunder
Dan Strother Oct 2 2004This is my latest, and nicest construct yet. I have deemed it Elysium, since the project just 'came together' and yielded the results I wanted with little fiddling. It's key features include:
Half-bridge of FGH50N6S2D IGBTs
CD4046 based PLL driver electronics (developed by Steve Conner) – this thing is basically immune to upset; I have been able to short the toroid directly to ground with no ill effects.
Adjustable staccato controller – Reduces power consumption and system heating for prolonged runs
No variac required, thanks to the reliability of the PLL and mains-synced turn-on afforded by the staccato controller
Remote dead-man switch operation
Sleek acrylic case
Additional information can be found on my website.
Elysium
1139330578 10 FT14 Elysium2
Tesladownunder
Tue Feb 07 2006, 04:46PM
Teslacoiler Oct 2 2004
Hi All!
This is my best VTTC.
was born with some pieces of my first VTTC (the first with autotransformer primary) for the occasion of first italian teslathon.
SPECS:
Primary: 52 turns of 2,5 sq-mm cable with PVC insulation wound on 16cm
diameter PVC tube, one tap every turn.
Secondary: 2230 turns of 0.224mm magnet wire wound on 8.2x50cm PVC tube
Feedback: 24 turns of 1 sq-mm, PVC insulated cable wound under the primary
Tank cap: 6.75nF 21kV MMC with 100 MKP-HQ capacitors in series-parallel.
Power supply: 1,1kVA MOT + level shifter + variac
total power: 1520W true power ( measured by double coil wattmeter, filament
power included )
sparklengt: 1-40cm, adjustable
note: fully adjustable via autotransformer primary for maximum voltage
or current in every load conditions
the official schematic is available here Link2
More pics available on Link2
Enjoy! smile
Ciao!
Fabio.
1139330801 10 FT14 4hv Vttcbig2 1
Tesladownunder
Tue Feb 07 2006, 04:48PM
teslacoiler Oct 2 2004
Yet another pic of my VTTCBIG2°
...... i love glowing plates! wink
Enjoy!
Ciao!
Fabio.
