  • Guests: 28
Linas (34)
Toasty (29)
05/15 Linas (34)
05/15 Toasty (29)
05/16 kg7bz (68)
HV Resistors for HV measurement....
Thu Feb 10 2011, 02:02AM
Contruction of the next prototype will now commence.
Related Thread: Link2
gchickusa
Sat Feb 19 2011, 11:42AM
gchickusa Registered Member #3698 Joined: Sat Feb 19 2011, 11:31AM
Nice resistors! Interesting project.....Depending on how permanent you want the enclosure Silicone RTV or a thermal conductive epoxy(Emmerson & Cummings) would negate the mess and headaches that oil introduces....getting a good seal is still a huge market issue today on oil-filled high voltages.
Sun Feb 20 2011, 12:19AM
gchickusa wrote ...
I was warned by the Application Engineers at Caddock:
*** To not use thermal epoxy, as it would place lengthwise force along the body of the resistor, then the resistor could crack and or change rsistence.
*** And not to depend on Silicone, as its thermal and specific heat are inferior to that of common oils.
So, food oil it is.
gchickusa
Sun Feb 20 2011, 10:13PM
Interesting comments from Caddock.....in 30 years we haven't had any resistors crack under pressure in expoxy....only by arcing, and we use two different epoxies depending on thermal property(dissipation) requirements. The silicone RTV has no thermal hold off, which is fine if you're staying under 300 or 400 watts.
Mon Feb 21 2011, 01:22AM
What epoxy are you using, and who is "we"?
EDIT: the "we" is...." Spellman and formerly Del High Voltage, formerly Bertan High Voltage " ( - Gchickusa)
Thu Feb 24 2011, 04:10AM
next resistors...
1298520658 2431 FT102386 Sam 0479russian
Thu Jun 30 2011, 08:23PM
I now use only two oils, for cheap cost i use Canola oil, for high quality i use yellow Olive oil.
For transformers and caps where the oil is part of the circuit i use Olive oil.
For resistors and already potted elements i use Canola oil for heat dissipation and electrical insulation.
I will be getting a 100 micron vacuum pump in a few weeks so i can get good with the vacuum degassing and potting.
New resistors for my O-scope probes....
1309465416 2431 FT102386 Ssx39
omegalabs
Fri Jul 01 2011, 08:45PM
omegalabs Registered Member #1521 Joined: Thu Jun 05 2008, 10:46AM
Someone know where can be bought these SMD HV resistors in small quantity?
There are 5kV ones, so building a resistor for 100 or 200kV would be really easy, and small. But I think they aren't cheap :(
Sat Jul 02 2011, 01:22AM
omegalabs wrote ...
I dont knowof a reseller for Nicrom, i was going to buy from them directly, before i checked Ebay,and found all of mine cheaper that way.
