  • Guests: 16
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
** Add your Tesla coil here **
Vigh holtage
Tue Dec 12 2017, 12:53PM
Vigh holtage Registered Member #61739 Joined: Wed Aug 23 2017, 04:43PM
These are my verry first 2 coils , bolth have a 2in dia secondary 10in long with 28awg wire and bolth have a 6-7 wrap vertical primary of 12awg thhn, one is bipolar with al electrodes and a single spark gap with a 10nf bucket cap and a 12,000v 20ma supply, the other is a standard coil design with a 6in topload and has a 9nf bucket cap and a 12,000v 75ma supply
Vigh holtage
Tue Dec 12 2017, 12:57PM
Here they are
1513083423 61739 FT14 20171026 222002
1513083423 61739 FT14 20171004 052931
Vigh holtage
Thu Dec 28 2017, 02:28AM
Vigh holtage here , and my coil...
secondary - 2in dia, 28awg wire 10in of wrap
Primary - 8 wraps of 12awg thhn wire
Around pvc coupling vertical
Tank cap - 9 nf wine bottle bucket cap
Power supply - 15kv 120ma nst bank
Spark gap - 4 tungsten electrodes
1514428134 61739 FT14 20171227 205307
1514428134 61739 FT14 20171227 205340
medved
Mon May 07 2018, 05:39AM
medved Registered Member #4338 Joined: Sun Jan 15 2012, 10:19AM
Hi all smile
my latest big VTTC project with a GU-5B tube with a discharges length of 105cm ! amazed
Schematics, construction details, photos etc are on my website: Link2
Specifications:
Vacuum tube: GU-5B 2,5kW triode
Secondary coil: 11x55cm, 524 turns, d=1mm
Primary coil: d=20cm, 28 turns
Feedback coil: 10 turns, HV cable, only impulse mode
Resonant capacitor: 1x 470p/15kV 40kVAr K15U1
f0_secondary: 629kHz
f_primaryLC: 565kHz
f_oscillator: 470kHz
HV source: 4,4kV AC, big 4kVA transformer from radar + voltage doubler = 12,4kVp (no-load)
Length discharges: 105cm
Photos:
1525670585 4338 FT14 Vttc Gu5b 470k15 B
1525670585 4338 FT14 Vttc Gu5b 470k30 B
1525670585 4338 FT14 Vttc Gu5b 470k35 B
1525670585 4338 FT14 Vttc Gu5b Human Topload17 B
Videos:
Human topload with me amazed
medved
Mon May 07 2018, 06:46AM
...and next big VTTC 2MHz project with a GU-5B tube with a discharges length of 70cm ! amazed
Specifications:
Secondary coil: 7,5x37,5cm, 154 turns, S=1,5mm2
Primary coil: d=12,5cm, 7 turns
Feedback coil: 3 turns, HV cable, only impulse mode
f_oscillator: 2MHz
Length discharges: 70cm
Photos:
1525675395 4338 FT14 Vttc Gu5b 61 B
1525675395 4338 FT14 Vttc Gu5b 67 B
1525675395 4338 FT14 Vttc Gu5b 77 B
1525675395 4338 FT14 Vttc Gu5b 81 B
1525675395 4338 FT14 Vttc Gu5b 84 B
Videos:
Wolfsangel1
Sat Sept 01 2018, 08:51AM
Wolfsangel1 Registered Member #61395 Joined: Wed Dec 28 2016, 03:44PM
ISSTC
Primary - 8 turns.
Secondary 8 cm *10 cm, 0.15 mm wire. Full bridge on gdt and K50H603. Current transformer on bottom of the secondary.
Sparks about 25 cm.
MRMILSTAR
Wed Sept 12 2018, 03:44AM
MRMILSTAR Registered Member #62119 Joined: Sun Feb 04 2018, 04:59AM
* Completed January 2018
* Totally self-contained for portability
* Single 833A
* Single MOT
* Separate variacs for plate voltage and filament voltage
* Power factor correction
* EMI filter
* 20" streamers with interruptor
Operational picture is with ion motor attached to discharge electrode running in CW mode.
4
2
medved
Mon Jan 07 2019, 06:20PM
Hello everyone ! amazed
I'm here again with my next tesla coil, this time it's DRSSTC
Specifications:
IGBT full-bridge HGTG30N60A4D
325Vbus
40-60us
max. 400BPS
OCD: 390Apk
Length discharges: 100-110cm
Secondary Coil: 11x30cm; 1091turns; 0,25mm
f: 166kHz
Drsstc Vyboje81 B
Drsstc Vyboje83 B
Drsstc Vyboje80 B
Drsstc Vyboje72 B
kaboooom2000uk
Tue May 26 2020, 03:58PM
kaboooom2000uk Registered Member #324 Joined: Thu Mar 16 2006, 10:28PM
Hi all, its been a while since I frequented the site, just wanted to share my work on a VTTC which continues to evolve with each day of isolation. Its by no means finished but it keeps me occupied.
It is based largely on the work of Steve Wards schematics, and advice from others I have made a working coil.
It's truly my first real experience with a VTTC, and was surprised at how forgiving they are. It wasn't long before I assembled a prototype on my bench and had it producing some sparks. Please excuse the crudity of the design as I am convinced it is far from optimal. Hopefully it is interesting.
Tube is a TY4-400 - capable of about 350W dissipation but earlier tests used an 812A which is a nice step up.
Transformer is a pair of railway transformers, at 1KW each, with 650V and 120V windings, I have hooked up the 650V windings in series to get about 1400V at 1KVA at full power into the multiplier.
Each of the 120V windings are in series and allow me to drive the pair via a 240V 8A variac. I made a crude interrupter based on an SCR and external signal generator which as you can see is not synchronised at all, but produces some interesting beat frequencies. I am trying to find a more elegant solution for this.
I am using Russian ceramic doorknob capacitors for my tank circuit and the secondary coil has a resonant frequency of about 750Khz with a topload, and about 1.4Mhz without, i estimate its about 900 turns of 0.25mm wire on a 50mm tube, I tend not to be too precise with the secondary as what seems to be important is determining the frequency and then working back to design the primary components.
Here I test the coil in CW mode with some large 220UF 2500V capacitors on a full wave doubler to get over the transformers low voltage. The result is a very quiet power arc, and due to the energy storage the oscillation continues long after the variac is set to 0V.
I suppose my goal would be to make a coil which operates in pulsed mode and can dump that large amount of energy in the capacitors into the primary, I am think maybe a hydrogen thyratron or something in place of the SCR to handle the peak current and voltages. Anyway hope you found this interesting.
Mon Jun 08 2020, 05:38PM
Welcome back. A sign of life in old 4hv forum.
