  • Guests: 22
Adam Munich (30)
Alfredo Texacca (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
5KJ 4 stage rail gun (complete)
ea6b607
Tue May 20 2008, 04:20AM
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
Ya your right, I did that backwards on mine. Anyways I just used the first sound peak from each channel. I had my recording set at 96000hertz so accuracy for measurement is .00001 seconds (make sure to use beginning of peak) at 20 feet~6.096meters my measure time was .0096seconds so 6.096/.00989seconds~ 616.38m/s +or - 0.6m/s due to accuracy limitation. Measurement accuracy will get significantly worse at closer distances or with lower recording frequencies. I originally thought of using optical sensors, but I figured the muzzle flash would mess that up,
badastronaut
Tue May 20 2008, 04:30AM
badastronaut Registered Member #222 Joined: Mon Feb 20 2006, 05:49PM
What is the time between the launch peak in the left channel and the launch peak in the right channel?
ea6b607
Wed May 21 2008, 02:58AM
0.01783seconds. By the way when I say peak I'm not actually talking about the highest point but when the sound begins to peak.
Gunner
Fri Jun 13 2008, 09:56PM
Gunner Registered Member #1397 Joined: Mon Mar 17 2008, 12:47PM
Cool...could you take some damage pics?:P
