Registered Member #95
Wonderful. Is the sound quality really crystal clear, and is there much/any noise from the streamers? My PLL class E coil is useless for audio modulating because the streamers hiss so loudly. I'm not sure if it's the PLL, my PSU or the low frequency that does it.
Registered Member #1232
Reaching - What material are the two toroids? I assume the RF drive transformer is Mn:Zn ferrite, and it looks like your RF choke is using the same material? A closed ferrite toroid is not really the best choice for the PA's drain choke, because it can saturate due to the DC current component. You might see better performance (better efficiency and cooler PA MOSFET) using a Type-2 iron powder toroid, or a gapped ferrite or stick inductor here. These generally work better as RFCs than ferrite with no air-gap.
Registered Member #89
Hi guys,
Yes, for drain chokes, best to use are the yellow-white iron powder toroids from SMPS output chokes. The choke only sees DC so there is no need to be worried about dissipation on it.
One thing I was personally wondering about from time to time - what *assures* that volt-seconds on the link choke remain constant in class E amplifier? While device is the choke sees full bus voltage for full time, but during off-time wouldn't it see sinusoidal voltage slope? Why doesn't this disbalance the Vs on the choke?
No don't use yellow/white iron powder (type-26) for Radio Frequency chokes (or green/blue type-52 for that matter! These materials are very lossy above a few hundred kHz and will turn a nice crispy brown colour quite quickly when exposed to rapid large flux excursions. You ideally want carbonyl iron powder like the red/clear type-2 toroids commonly used by radio hams. I forget the other type, maybe 6 or 8? Gapped ferrite is okay though.
The drain choke sees a voltage equal to the supply voltage minus the drain voltage of the MOSFET. The time-averaged value of the applied voltage is zero. Energy that is pumped into the magnetic field when the switch is closed, is released to the resonant tank circuit when the switch opens. It is similar to a boost or flyback converter in that respect.
I don't see what is the problem, how you mean this? Since DC link choke carries only DC current with very small ripple, although it sees AC voltage. I always use them on royer oscillators without any problems.
Matt Bingham has used them a lot for class E amplifiers at very high frequencies without any problems too.
I thought you used them as well Richie, for class E amps. Why aren't all our chokes frying then?
Long ago I was also afraid of using the powder toroids for link chokes thinking they are 'lossy' but everyone assured me against that. And indeed they work rather well, once enough inductance is used to keep ripple small... (??) High frequency actually seemed to be beneficial by allowing to use less inductance.
It depends on the power level you are running at Marko. Type-26 is the cheapest crapiest grade of iron-powder for use in very high-volume low-cost SMPSUs operating the tens or low hundreds of kHz. If it suffices for any other particular application then great, because it is dirt cheap, but there are many better materials for RFCs.
My point was that at high power levels and high frequencies where only the right materials will survive, type-2 Fe powder is best for minimal heating as the drain choke.
