  • Guests: 13
cbfull (52)
Steve Ward (39)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
Secret PIRANHA-II files are released
Mon Sept 03 2007, 10:54AM
AC resistance and Q of the resonator don't matter in a properly designed coil. People found that out by trial and error over the years on the Pupman list, so nobody really bothers to investigate it any more.
The reason is that the unloaded Q of the secondary can be a few hundred, but we find in practice that with a good streamer output going, the loaded Q drops to about 10. If you feel your secondary coil after a good run, it barely gets warm.
Another way of stating this would be that if the coil was so badly designed that the unloaded Q mattered, you would be frustrated by the poor spark output, scrap it, and make another one. :P
In all my simulations, I've always ignored the secondary wire resistance and treated it as an ideal LC circuit. If you're in a hurry, you can often just about ignore the primary resistance too suprised
As far as I'm concerned, the only missing "puzzle piece" is a real-time dynamic streamer loading model. Since my mental (and computer) model of the Tesla coil is just a lossless matching network that connects an inverter (or pulse source) to a streamer load, like I explained above, it's useless unless I assume some kind of streamer load impedance to match into. The problem is that that impedance is highly non-linear. The network also has to cope with infinite load resistance to get the discharge lit in the first place.
I think Terry is working on one in ScanTesla as we speak. Once that is complete, he will be able to model a complete Tesla coil system in the box and nobody will need to make actual coils any more wink
