  • Guests: 16
AlexRU73 (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
Function and form....
Fri Nov 16 2018, 12:16AM
Plasma wrote ...
You're still DC based
About the first,one is a voltage source, ttop leg,the second is a current source.
The one you posted for full isolation will need a cap from top left of the jfet to bottom right,adjust for series,but its still DC,try using 2 MOSFET with diode's at source to clip both ways
How is it still DC biased? There are two 10u caps blocking any DC?
If you mean there is still a voltage present, I did the maths..... there is 12.66V across the fet 'at rest'..... the load resistor is 246 Ohms.... the DC resistance of the tank is around 0.8Ohms..... the tank itself 'sees' 50mV..... I don't expect that to be an issue.....
Have I missed something?....
EDIT: I do now have all the components to build a long tailed pair, but I'd use these JFET's if I were to do so, I don't like the hard clipping of mosfet's..... That's one reason I'm only using jfet's for this, and my other audio projects.....
What advantages would a long tailed pair give?
Fri Nov 16 2018, 01:58AM
Plasma wrote ...
What value should the diagonal capacitor be?
(Sorry mods for breaching the rules..... New question..... I don't do it often..... )
Plasma
Fri Nov 16 2018, 03:28AM
The diagonal caps should be greater than 10uF ,but that covers a driving ac source,if you want to drive a amplifier just match the series capatance
It DC bais because the voltage drops to from peak, but doesn't go negative
Fri Nov 16 2018, 06:22PM
Plasma wrote ...
The load is three tiny coils with a total inductance of just over 1mH. It can be treated like any other coil, say a small speaker..... It also has a series resistance, currently of around 235 Ohms.
There is no DC current, due to the blocking caps.....
It's basically a single ended class A amp driving into a coil with a series resistor....
While the impedence of the coil increases to around 80 Ohms at 10kHz, at 0Hz the coil 'sees' 50mV.
If a single ended Class A amp works fine with a DC voltage bias, surely this should as well?....
Am I missing something?..... I could implement a long tailed pair, or even an H bridge, but if single ended class A is good enough to drive a speaker, why is this circuit not suitable to drive a siminar inductive load?
EDIT: When I say single ended class A, I mean a parafeed type circuit with a parafeed capacitor that blocks the DC component, so a gapped O/T is not required, as there is no DC component.
Sat Nov 17 2018, 05:50PM
So, New information....
I've been doing a bit of online research, apparently, this topology, with the cap referenced to the source is generally called 'ultrafeed topology'. It has pro's and con's, the cons being about isolation..... in the case of failure of an O/T, the plate voltage is not isolated. That's not really an issue with a drain potential of 19V. It appeals to me because it defies the rules of the usual descriptors regarding voltage and current, it's effectively both. It doesn't really matter in which leg you place the cap, it's in series between them.
It also excels as an ungrounded low impedence source.
Anyway, back to the current question, regarding how 'isolated' this circuit needs to be. I've come to the conclusion after extensive googling that the issues regarding inadequate isolation all seem to relate to ground loop problems. That was my understanding when I designed it and that is why I chose the ultrafeed topology. I'm also aware that these were traditionally driven from O/T's running from tube stages. As the load is just an inductive load, like a transformer primary, I can't see that any more isolation would be required, although I do understand the meaning of 'total isolation', especially when related to safety and higher voltages. I propose to order a couple of small audio transformers for delivery on Tuesday, and then try my original circuit both with and without 'total isolation'. That would appear to be the most pragmatic approach, before I start building a long tailed pair, or H bridge, or something.
There is another isolation issue relating to power supply ripple rejection, but my power supply is completely ripple free.
In the meantime, I'll get on and build the recovery stage.....
I do plan to use the transformers for other purposes, one is ideal for driving a long tailed pair, the other for driving an H bridge. (It's likely that the power stage of an amp I'm building is likely to consist of a class A power JFET H bridge, with choke regulation. Something I've never seen attempted before wink )
Transformer is 2W, 1:1, nominally 3 Ohm, but is good for 15 Ohm, 20Hz, which is well below what I'll be putting through it here.
EDIT: There appears to be an issue with some of the links to images below..... I'll try and sort it.
EDIT: Fixed it.....
1542477013 3414 FT183122 Parafeed1
1542477013 3414 FT183122 Parafeed2
1542477013 3414 FT183122 Parafeed3
1542477013 3414 FT183122 Parafeed4
Mon Nov 19 2018, 09:56PM
Here's the 'recovery' circuit.... the circuit that amplifies the output from the spring reverb tank back up to line level.....
I could leave out the input gate resistor and up to four capacitors, but as I'm testing it at the transistor voltage limits, they do add some protection in the case of transistor failure.
This circuit has yet to be tested, but is basically two of the boost stages that drives the output stage for the tank input.
More to come in due course.....
1542664603 3414 FT183122 Dscf2007
EDIT: The input cap and resistor form a high pass filter, although it currently passes pretty much everything, but could be 'tweaked' if required, also there's room on the left hand side of the board to add a low pass filter if this turns out to be required.....
Shrad
Wed Dec 05 2018, 07:18AM
would I have known about the load, I wouldn't have told you about isolation :) the transformer is giving you that already so no real need of long tailed pair or anything, just DC blocking will be sufficient
I personally tried hooking up a PAM8403 module to a small toroïdal transformer to match a tube phase splitter, or even a PP stage directly, to avoid half the iron with replacing power supply by a PLC stage with a current limit... would have made nice, easy instrument amplifiers (please give me shares if you start a business on this idea ;) )
Sat Jan 05 2019, 11:37PM
Shrad wrote ...
It works fine without the transformer. Once I got thinking I realised there was no good reason not to use one, although the only good reasons I could think of for using one is that the famous Fender units from the Sixties all had transformers, so maybe it was a part of the sound. Also, it was simpler to reverse the phase, which I did do. Phase shouldn't in theory be important in this application (reverb driver), but the waveforms seem to match better one way round. I'm still playing with it all, added active splitter and combiner, it's pumping 50mA or more, still playing with trimpots and cap values, and I need to add attenuation to the output.....
