  • Guests: 24
GODSFUSION (37)
Zajcek (37)
ElectroDog (33)
sportcoupe (56)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
Fullbridge SSTC Design Questions
Sigurthr
Mon Feb 22 2016, 02:13AM
Just make a simple TTL inverter (NPN, pull up on collector) and use two non-inverting drivers.
Wolfram
Tue Feb 23 2016, 08:22AM
Sigurthr wrote ...
Bipolar transistors take a while to come out of saturation, and an inverter made with one can easily take several microseconds to turn off. At typical SSTC frequencies, this can be a large fraction of a cycle, so the circuit will not function correctly, there is some good info here: Link2 . The same circuit made with a MOSFET will work much better. An inverter IC like the 74HC14 would be somewhat faster again, and have more symmetrical delay.
Sigurthr
Tue Feb 23 2016, 07:02PM
Thank you Wolfram, that is actually very valuable information. The nanosecond (and often, single microsecond) scale is hidden from me as I lack the equipment to visualize it.
I've used simple BJT inverters in SSTC drive circuits before, but only as stop-gaps until I got proper gate chips in, guess I just got lucky with the f0.
woodchuck
Tue Feb 23 2016, 07:44PM
woodchuck Registered Member #39190 Joined: Sat Oct 26 2013, 09:15AM
Wolfram wrote ...
Bipolar transistors take a while to come out of saturation...
...which is a good reason not to drive them into saturation. Hence accommodations like Baker clamps or a reverse-biased Schottky diode between base and collector.
