  • Guests: 33
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
5 MHz CW TC with PLL tracking oscillator
first  2 3 4 5
Wed Oct 18 2006, 05:37PM
The worst 'drawback' of class E I found is it's sensitivity to change in load impedance (and reactance).
If I didn't let out a breakout on my little coil topload peak coltage would become enormous and coil would start drawing insane currents, burning most of power on the mosfet due to mismatch (heavy over-dampness). I would have to drastiically retune the coupling to make coil work like that and then I would get puny output with breakout point.
Winding HF coils like 'normal' coils probably isn't best practice at all (I had over 1k unloaded impedance), but that's what we got...
WaveRider
Fri Oct 20 2006, 09:49AM
Hi Firkragg! 1k input impedance should not create problems, unless you risk "overvolting" your MOSFET. (BTW-how did you measure the impedance?) The problem is if you happen to start up near the series resonant frequency of the coupled coil...and particularly if your MOSFET is seeing a capacitive load reactance (which switching circuits do not like very much).
Large currents will result. (I've smoked a few MOSFETs verifying this theory! cry )
I've done some computations using a rigorous model that indicate that the highest fields are attained at the top of your coil between the series and parallel resonances. At the peak voltage point, the primary feedpoint will likely exhibit a fair bit of capacitive reactance...which, for the health of your MOSFET switch, is best to tune out using a matching network. See the bottom of my PLL tesla coil page where I try to continually add stuff..... (I couldn't resist giving my coil a name from Norse mythology...given the trend here at 4HV! wink )
Fri Oct 20 2006, 11:26AM
Unloaded impedance isn't measured, just roughly estimated using DC resistance and skin depth at my operating frequency.
I don't know wha is the real impedance when coil is loaded with CW spark though..
Too high impedance is always bad (bad Q factor = lower voltage rise, lots of heating in the secondary, etc).
I would just run it up with PLL and it would work unless I detune from class E (thn mosfet dies from overheating).
You can see more pix of the coil (with new secondary) here Link2
WaveRider
Fri Oct 20 2006, 12:15PM
How can you compute impedance from skin depth and dc resistance for a non-arcing coil? (Skin depth can give you the AC surface resistance of the windings, but nothing else..) You are modeling an inductively coupled resonant circuit.
If the input impedance is dominated by inductance (just below the parallel resonance), little current is drawn from the DC supply... If, on the other hand, you excite the series resonance, the low feedpoint impedance can cause excessive current to flow in the MOSFET drain...thereby smoking it. Somewhere in between generates the highest voltage in the coil.. I discuss in my PLL Tesla coil page that it seems that the "maximum spark" is obtained where the feedpoint impedance exhibits significant capacitive reactance (which puts strain on switching elements). Of course, the loading of the primary with any capacitance (MOSFET drain capacitance, parallel drain capacitor, for example) causes more capacitive reactance to appear as well as introducing a second resonance that can possibly kill mosfets.. I am putting together some computations that show the effects of this..
To stabilise things, some series inductance seems to be needed in the primary circuit.. As you see in my driver circuit, a variable parallel capacitance can be used in conjunction with a bit of extra series inductance to adjust for ideal match while the all-pass phase shift network can correct phase errors introduced by the matching network. I can freely dial up class E or class C operation and anywhere in between..
Fri Oct 20 2006, 08:41PM
Oh, stupid me ^
I see I nowhere mentioned that I used prsimary itself as a charging 'choke' instead of separate class E stage.
With big enogh decoupling cap it seems to work just as well.
AFAIK (sccording to r. burnett) when coil is tuned into resonance it's unloaded base impedance *is* just the AC resistance of windings, and it grows bigger when sparks load the coil.
I never had any serious 'out-of-tune' problems since coil seems to draw relatively little current no matter if it is higher or lower than resonance.
The 'capacitiveness' thing you are mentioning doesn't seem to be a problem at all as capacitance is very small and I don't think it will look like soemthing more than few hundred pf on the mosfet.
When I decide approximate number of primary turns the fun begins - lots of moving up-down and changing number of turns, until best mach and nicest class E waveform is acheived.
(toast for a 'scientific' approach ^^)
WaveRider
Sat Oct 21 2006, 09:17AM
Oh, stupid me ^
I figured I was missing a bit of info..
You are quite right...as long as we are talking about series-like resonance. Add in the effect of the coupling (primary) coil on secondary resonant frequencies and things become more complicated ..even more when we add capacitors/inductors to the primary circuit..
The effect I am describing may or may not be a problem... Depends on many things (coupling, losses and loading, etc.) I just found it interesting to model and discover that the max voltage at the top of the coil may not necessarily occur at the "resonant" frequencies seen at the primary coil input terminals.
Yours is a perfectly good way to handle the coupling problem. As the coupling goes down, the capacitance effect decreases (as primary self-inductance begins to dominate). I designed my matching circuit as an attempt to transfer maximum power to the secondary while maintaining something close to class-E transistor switching (using a variable capacitor to vary the primary coupling). It seems to work... Yesterday, I ran the coil for two hours. The transistor was barely warm to the touch (I was using fan cooling.) The base of my coil did get a little bit warm, tho' not enough to hurt the PVC insulation or coil form...
Sat Oct 21 2006, 11:52AM
It's a base impedance, considered when secondary is unloaded and without the primary mess.
The base of your coil is getting warm because secondary is coupling capacitively to primary, causing heavy dielectric losses in PVC.
I melted the base of my first secondary that way, so I use a wide former-less primary wich is set higher to keep coupling same.
ragnar
Sun Oct 22 2006, 01:49AM
The base of my secondary gets hottest regardless of where the primary is. =P
It's probably something to do with that big copper plate I put there. wink wink
WaveRider
Mon Oct 23 2006, 07:20AM
Hi Firkragg and "balsamplack" cheesey
The lower windings of the coil get hot because the current near the base of the coil is maximum (can be amps to 10s of amps depending on power level, loading, etc..)
These HF coils behave a lot like a 1/4 wave transmission line which is open at the end and shorted at the other. Current is high at the shorted end (where the coil is connected to a "ground-plane" or faraday cage) and voltage is high at the open end..
I did some simulations here when I was attempting to get my Royer/Armstrong coils to work. (The primary geometry is a little bit different, but the resonator behaviour should be the same..) This plot shows the normalised coil current along the helix for a coil with no topload and the primary wound right at the base. It is highest at the base (0m) and small at the top (25m), therefore copper (ohmic) losses from the current are highest here...so the base gets hot!
WaveRider
Mon Nov 20 2006, 02:20PM
I have updated the original post with some field measurements after installing the driver board in an RF tight box.
I'm working on an audio-mod board. The circuit is based on the TL494 (similar to EVRs Plasmatronic driver).
Also, I have made some minor modifications to the PLL/driver circuit. I will post these to my web site in a couple of days.
first  2 3 4 5
