  • Guests: 37
lokeycmos (42)
05/24 Simon Barsinister (62)
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
Most spectacular failures
the_anomaly
Tue Feb 21 2006, 06:56PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
Well this has already been labeled extreeeemly dangerous on the last forum but I though I would post it so the new members saw it. exploding wires.
Hazmatt_(The Underdog)
Wed Feb 22 2006, 02:34AM
My heart still sinks when I see anyone, I don't care who, grab a hot lead with pliers.
joshua_
Wed Feb 22 2006, 03:29AM
joshua_ Registered Member #61 Joined: Thu Feb 09 2006, 05:50AM
Nick wrote ...
Yup.. Just wanted to make it known that this thread is not to be used for "I blew my self up gooder than you hurr hurr"; battle scars are really not something to be proud of with HV (see that debate in the archives). Interesting stuff that I've seen so far, though. Some of the blown FETs are up there... I wouldn't want to be near that when it happened, though!
Self Defenestrate
Wed Feb 22 2006, 03:37AM
One of my most spectacular failure was while charging up a bank of four (two in series)200v 5600uf caps off a camera flash board. Right after the ready light came on, the transistor shorted and the caps somehow discharged through the transistor, completly vaporising it. It was one of my early expirements, so I was already real nervous around the setup. The first failure's always the loudest, dosen't it seem?
Wed Feb 22 2006, 12:07PM
You could be spooked by smoking wires and grab a hot lead dead
I had lots of failures with that connecting clips (on low voltages) usually they dont withstand ampere or two of current, mot was obivously too much...
Always use chicken stick from long distances (if something explodes) smile
the_anomaly
Wed Feb 22 2006, 04:29PM
After that I upgraded to use one of these 20discharger
On the part I hold I rapped electrical tape around foam to make it have a comfy grip. Its also good to make sure caps are discharged. The "buisness end" is just some copper attached again with electrical tape.
Chris
Sat Feb 25 2006, 04:32AM
Chris Registered Member #8 Joined: Thu Feb 02 2006, 04:34AM
About the only really spectacular failure I've had was the time when a diode bridge shorted while charging my big caps, dumping over 10kJ through the charging leads. That was scary. suprised
ragnar
Sat Feb 25 2006, 06:02AM
I think..... say, you've got a video of that, don't you chris? IIRC :P
Xenon tube used as triggered spark gap a few times:
Sun Feb 26 2006, 07:46PM
This was a startle. I was trying to run my flyback off of mains, with a 10W load resistor..... It exploded and scattered burning shards all over the floor. It was a wooden floor too.... cry
1140983165 95 FT1665 Uzzors Load Dead
I know, real safe setup..... the fuse is a piece of wire, which explains the failure.
Sun Feb 26 2006, 08:24PM
A loud bang from my first half bridge DRSSTC, with only 24 V on IGBT gates and insane high ON times.
http://www.geocities.com/gemaria_ro/ONfailure.AVI
Enjoy
