  • Guests: 22
AlexRU73 (39)
05/18 AlexRU73 (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
Secondary Coil Terminations
Fri Jul 07 2006, 05:57AM
Terry,
In your magnetic field/energy analysis,
I see no magnetic field component due to the secondary
which I imagine will be significant/extensive due to;
- the physical size of the secondary
- the resonant current
e.g. B= (Uo x N x I) / (L x2) at the end of the solenoid (from memory)
The relative phases of primary and secondary current will vary during ringup
causing primary and secondary fields to add in-phase for periods of time,
so for worst-case just add the two fields arithmetically.
Terry Fritz
Fri Jul 07 2006, 08:53PM
Hi,
I did the same thing for a cone primary here:
But in these plots, the secondary is only air and just outlined for reference. I had only been using the program for ten minutes and I did not (and still don't) have any idea what I am doing cheesey
But here I did model in the windings as copper with zero current. When the primary is at maximum current the secondary is at zero current. This is what I got:
I don't see a way to set up a current gradient along the coil.
The program also does electrostatic fields too. It is not too hard to run just a bit awkward. Sort of cool and is free wink)
Cheers,
Terry
