  • Guests: 13
cbfull (52)
Steve Ward (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
isolated gate drives
Thu May 11 2006, 03:05PM
blackplasma wrote ...
Hey, EVR, good to see someone looking at my lonely lil thread here.
Perhaps you could utter a few words of guidance regarding my [strange] ideas... ^^
Do you have a schematic to post???
Thu May 11 2006, 03:57PM
OMG, EVR, are they diamond? Or kryptonite? confused
Thu May 11 2006, 04:55PM
As I could figure out reverse voltage is the main reason why schottkyes haven't pwned 'ordinary' diodes yet. For what I know 600V is the highest voltae silicon-carbide diodes acheived, and these still seeh relatively hard to get, and they don't have some great current rating (about 12A at most)
Thu May 11 2006, 06:15PM
They are diamond based. And basically they are prototypes only provided to us for an R&D effort we are working on.
ragnar
Fri May 12 2006, 02:17AM
EVR, here's a schematic...ish.
Wilson
Fri May 12 2006, 09:05AM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
There seems to be a small error in regards to the schottky/freewheel section on your schem.
The schottky in series with the source of the FET is supposed to have its cathode connected to the anode of the freewheeling diode tongue
Effectively, what you've just done is to isolate both the body diode AND the freewheeling one using the schottky, meaning that something will probably so pop or smoke when you get reverse current
Anyways, using an independant gate driver for each FET isn't quite a bad idea. You can drive the gates alot harder, and makes paralleling mosfets a more feasible idea.
Keep up the good work
Wilson
Fri May 12 2006, 10:13AM
Ya, Wilson is right. You should also have at least one pull-down resistor connected across one of those 1N4148s. I would tend to put one ~470 ohm resistor from each UCC input to ground. It's just to stop the transformer winding floating around.
Bodydiod
I found this on Obi-Wan Burnett's site Link2
ragnar
Fri May 12 2006, 03:11PM
Ah yes, schottky/body diode etc... OOPS on my part.
I'm getting the general impression from the datasheet that I should have my low-impedance/bypass caps on the output side of the UCC...
I'l considering sacrificing my principles and placing them "across" the output rail on pin6/7...
Should be relatively neat.
Part Scavenger
Sun May 14 2006, 02:04AM
One problem. I don't see an audiomodulation circuit. tongue
Looks pretty cool, and the layout is just sexy!
ragnar
Wed May 17 2006, 10:17AM
I seemed to have had this board all perfect and nice, but had to mangle it by fitting that power schottky in there (to bypass the FET's body-diode)...
I've taken the zeners off the board because they were a PITA, and it's reasonably easy to clip them onto the MOSFET nice and close/directly. The gate resistor now has to go under the board because of the schottky being in the way. I'm not happy with the enclosed loop area between OUT1/SOURCE/GATE/OUT2, but it'll do.
I've got Steve-Conner-memorial schottkies on the outputs of both UCCs, and signal diodes on the inputs to clamp my +/-5V signal just in case it rings to something silly, and a 1K pulldown on each UCC input.
I've also put the power bypass caps on the output side of the chip and thickened up the MOSFET and DIODE and SCHOTTKY tracks.
I've got the UCCX732X datasheet here, and they're available in DIP8, SOIC8 and MSOP8... and funnily enough, the MSOP8 has a power dissipation rating almost 3 times that of DIP8 (1370mW versus
500mW)... it also has a C/W temp rating better than 10 times that of the DIP, when properly soldered down on its tinned thermal pad.
It's very tempting... USD$54 for 25ea of the MSOP UCC27322s (yes, TWO-7322 is rated for higher die temperatures than the 37322)...
They (the MSOP packages) would also be a much better fit when it comes to snuggling up to the FETs regarding loop area...
Has anyone got experience with the MSOP UCCs? Please rant here!
Any overhauls I should make to the layout before committing?
-Matt =)
Thanks mod, I forgot GIF's aren't resized.
