  • Guests: 7
Finn Hammer (72)
Blue Adept (43)
Nickel (68)
05/17 Finn Hammer (72)
05/17 Blue Adept (43)
05/17 Nickel (68)
Diffusion pump project
plazmatron
Mon Oct 12 2009, 05:42PM
Steve McConner wrote ...
I recently found an Edwards vacuum coating machine in the uni's junk pile, and it looked to me as if it just used a length of plastic hose between the diffusion pump and the backing pump. The clear stuff with the reinforcing braid.
I never figured out a way to dismantle it or get it off campus without getting in trouble, and it's now been rained on. frown
Thats a shame! They are very cool toys! I manage to get two off of evilBay for just a few pounds, so I`m all set up.
Yes reinforced PVC is often used for the backing connection, since outgassing on the low side is minimal, and the rotary should be able to handle it. Often a spring is pushed up the pipe to stop it collapsing under vacuum.
I will be modifying the rotary pump connections again, by having two 10mm pipes going into a 15mm. Microbore is still much too thin for my liking, plus I want to get the 3inch pump up and running too, which will require the backing bump to pull at least 85l/min, so I need much larger diameter tube, and shorter connections.
Les
Wed Oct 14 2009, 02:31PM
Awesome! Your project is truly inspiring. I had no idea diffusion pumps could be found so cheap, I'll have to keep an eye out for one. Are you going to try glass-blowing with this setup?
plazmatron
Wed Oct 14 2009, 06:58PM
Uzzors wrote ...
Yes, I am, I have been playing with soda glass tubing, however I still need more practice to get up to a reasonable standard.
I also need a better heat source too. I have just got a Neon sign catalogue, and their prices for neon sign electrodes seem reasonable, and also come with sealing stems too, however I will practice some more with scrap glass, before purchasing some.
For the time being, most of my experiments will be done in demountable chambers. This is dead easy, since there are hundreds of candidate chambers kicking about, for example the glass rolling pin shown in the previous posts, and just today, I was using a small Salmon paste jar! These little jars are great, as they are very thick (4mm), and easy to drill holes in. I built an experimental Lenard tube today with one. It worked for a short while, until the electron beam punctured the Aluminium foil window frown More voltage, and less current next time I think!
Les
Wed Oct 14 2009, 09:16PM
Great stuff, can you post some pictures of your Lenard tube?
I've found a source for both a little shop vac like the Javac you have, and borosilicate glass here in Norway. I'm debating whether I should get into this now or wait until I'm done my studies at the moment. Seeing you doing this is really tempting me! amazed
Thu Oct 15 2009, 12:32AM
Eirik, finish your degree or you'll end up hanging out on corners in downtown Oslo!
BUT - since the true enthusiast can never really be deterred - you may not know that you can produce all kinds of interesting soft X-rays at the pressures obtainable by the Javac alone by plasma discharge.
The problem for most folk is that unless you have a pal in Brighton who will send you a Ne-CH4 proportional counter tube with opposing Be windows,* it's pretty much impossible to measure X-rays much less than 10keV, as I'm sure you know.
So, with the Javac, or whatever pump will get you down to 20 millitorr you could make plasma discharge X-ray tubes with Kapton exit windows for not very much money.
Plazmatron has the Devil's Luck, and you could watch and wait in ebay till the Crack of Doom and never find another diffusion pump for NOK 135.
As for these very soft rays: as well you know, the softer the nastier. I think you'd absorb about 99% of a 5keV
'mistake.' Just because they're 'soft' doesn't mean that there aren't plenty of them either. smile The plus side is that shielding costs are very low indeed.
Did I send you a BPX-65? If you take the lens out, it will go down to about 2keV, and detect individual X-photon strikes with nearly 100% percent quantum efficiency, the attenuation of the rays by any intervening air being a limiting factor.
Imaging, however, becomes increasingly problematic as we descend from 10keV.
* Generally valued at a good piece of reindeer sausage or dried reindeer meat.... smile
plazmatron
Fri Oct 16 2009, 04:03PM
Uzzors wrote ...
Hi Uzzors,
yep, check these out:
1255708900 1134 FT77678 Lenardanonde
This is a view of the foil Anode. A 5mm hole is drilled into the base of the jar, and the foil, is imply superglued over it!
This is ordinary household foil, and the 5mm window can easily support the high vacuum.
1255708900 1134 FT77678 Lenardrun
This is a view of the tube running. The blue glow, is a result of a thin layer of electron sensitive phosphor sprinkled on the window.
I made a shorter tube today, and finally observed the emerging electron beam first hand!
This tube was sprayed black, as the light from the filament easily washes out the dim glow.
1255714011 1134 FT0 Lenardglowjpg
The dim blue "jet" exiting from the centre of the tube looked to be about 10mm long, at 80kV, however there was significant light in the room.
Shortly after taking this photo, the Aluminium window punctured again, I think its time to invest in some Titanium foil, and give that a shot.
I`m with Harry on this one, do complete your studies, but, at the same time, always keep an eye out for cheap bits and pieces as they show up, I'm not that lucky!
Fri Oct 16 2009, 05:43PM
That is amazing :-o
A little ebay searching turned up some 9um (.3mil!) thick Ti foil, I wonder if it would hold to 15psi or not
Otherwise you can get the 3 mill stuff
What are you planning to do with this new toy?
plazmatron
Fri Oct 16 2009, 06:20PM
... wrote ...
That is amazing :-o
Thanks for the link, I was just having a dig myself!
9µ should be easily able to handle the the pressure, the window is only 5mm diameter after all.
I hear that ordinary kitchen foil is around 16µ so 9µ in Ti should be ideal.
Well the diff pump will be used for allsorts of vacuum work, the Lenard tube was something of a diversion smile
But, since it is a very interesting diversion, it will have to be scaled up a little. I figure a 250kV tube would satisfy my curiosity!
Les
Wed Oct 21 2009, 06:57PM
Hi Harry, you did indeed send a BPX-65 over, along with some organic gas Geiger tubes for lower energy X-rays. I just need a gigaohm resistor and some time off for Christmas before I make a counter with them. It'll be fun/scary to see how much radiation leaks from my X-ray setup. Those Javacs go for the same price as a cell-phone, so they won't set me back too far. After seeing this it's hard not to jump into it, but I'll stick to my studies for now, if for no other reason than that darned polyprojectilitus which has me still doing projects I planned years ago!
That's too neat Leslie! Have you considered irritating plexiglass to see whether you can make Lichtenberg Figures? Maybe not near the same scale as Bert, but shouldn't it be possible granted you use a thin sheet and lot's of irritation time?
Thu Oct 22 2009, 01:46AM
plazmatron wrote ...
Nice work. I guess the thread is drifting from diffusion pumps to Lenard tubes.
So, though this is probably preaching to the choir:
A foil too thin to span a 5mm hole, may be able to span a dense array of smaller holes.
Here is one patent about supporting and heat-sinking a large foil window for electron beams, using finely spaced parallel fins on the vacuum side. Check out the figures: Link2
These guys spanned a 38mm window with 0.002" (51 µm) Al foil, by making a simple but very strong attachment between the foil and its supporting rim. Link2
