  • Guests: 18
AlexRU73 (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
811A VTTC
Wed Apr 11 2007, 07:40AM
Vaxian Registered Member #635 Joined: Tue Apr 10 2007, 01:56AM
That happens allot with VTTC's (nice sparks, then they deminish)
Something is getting hot I suspect. Have you checked the grid leak resistor? 10 Watts sounds a bit underrated to me. I know all about the use what you got method though, don't think I am getting critical, just making suggestions.
Do you have a topload at all? A topload can improve a VTTC quite a bit. Something small, around 3" for a 3" OD secondary. I can suggest an El-cheapo hardware store topload if you like, or see some of my other posts.
Look forward to seeing how your coil progresses, I am deep into VTTC country myself, just started my second, don't know which tube I'm going to use yet but already started the power supply & grid leak mounting.
Good luck, will watch for further posts about your coil, & pics?
Dan
