  • Guests: 16
cbfull (52)
Steve Ward (39)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
Strange datasheet error of RLP434
Fri Oct 24 2008, 11:56AM
Just out of interest, why didn't you use an already known modulation scheme like Manchester encoding, and then put a known error-correction protocol on top of that, instead of your own adhoc scheme?
It sounds to me as if your confusion is caused by your trying to implement error checking and modulation on the same layer: by the very fact that you called pulse-width modulation a "protocol". Issues like telling 1s, 0s, and start/stop signals apart should be taken care of at a layer below the error checking code, whose job is then just to tell whether the sequence of 0s and 1s received is the same as was transmitted.
The simplest error checking scheme I know of is to always send the same data twice, and have the receiver ignore everything until it receives two identical packets in a row. I think RF garage door openers worked that way, and you could put it on top of your existing modulation system. If it's unacceptable to miss updates, you could send the data more than twice.
