  • Guests: 13
Dalus (34)
Kizmo (37)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
SSTC questions
Bauerb2
Mon Oct 01 2007, 09:52PM
Bauerb2 Registered Member #973 Joined: Tue Aug 28 2007, 07:32PM
while working on my own sstc i felt the gate drivers to get rather hot. i fixed this by adding two electrolyte 22uF caps in series, negatives terminals soldered together, with all this in parralell with a 100nF ceramic cap. this is in series with the tc4429 output. i see on the schem you have that there is one 4.7uF in series. it might be worth a try to try my idea (taken from this site Link2 )
its worth a try, it made my rise/fall times much quicker. (@ 380kHz sec)
-pz --Andrew
Dago
Mon Oct 01 2007, 10:48PM
huben Panev wrote ...
So hire are the traces. They are the gate - source signals. The top one is with 2 ICs (like on the schematic) and the bottom one is with 4 ICs (2 in paralel). The scope is set to 0.5 micro seconds/div and 10V/div. So what do you think about them ???
1191262254 931 FT31805 Pic 4347
1191262254 931 FT31805 Pic 4346
What kind of decoupling do you have for the gate drive chips? It is absolutely essential to have atleast something like a 100nF ceramic and a 10-40µF tantalum OR low esr electrolytic cap as near as possible to the Vcc and GND pins of the gatedrive chips to achieve fast risetimes. The chips do get hot, mine get too hot to touch comfortably without some airflow at 50% duty cycle.
CT2
Tue Oct 02 2007, 01:57AM
Yeah as stated previously your gate drive chips will get hot. You need caps on the supply pins (as close as possible). I use a 15uF tantalum and a bigger electrolytic as close as I can get them to the chips and then a 1uF ceramic practically on the pins, even still they run hot. So I had these little heat sinks that fit perfectly on the chip so I just slopped some thermal grease on the chip and stuck the heat sink on. With even a little air flow they run warm but not too hot.
1191290138 180 FT31805 Dsc 0015
The tantalum is hidden under the heat sink.
About the phase/frequency relationship... well I don't even own a scope so I've never looked at what my PLL is doing, so can't help there.
Dr. H.
Tue Oct 02 2007, 05:43AM
Thanks for the replys guys. smile I've copied the circuit with no changes, so for decoupling on the drive chips i have only one 4.7uF and it is electrolitic rolleyes . Today i will add some tantalum and ceramic condensers. For the decouplink i use 3uF (on the picture of the board the 3 yellow caps put side by side. Are this good ?
Bauerb2 - thenks for the idea. I will trye this too. Is there any chance that the waveform looks like this due to the ferite core (it is NOT the yellow one from ATX. Also could this be due to too much windings on the GTD (15 primary and 2x15 secondary )
CT2 - very nice design, i too may trie something like that smile
Tue Oct 02 2007, 10:01AM
On the core you are using you won't need to use more than few turns for 450kHz. See this Link2
Your drivers are also inherently a bit slow. I would use UCC's whenever I could.
Dr. H.
Tue Oct 02 2007, 10:12AM
Hi Marko, yes the ICs are slower than the UCCs but i can't find to buy them hire in Bulgaria, so i have no choice cry
Also in the schematic it is shown to use 16 !!! turns. I also thought that they are too much but after all i winded 15. Hire are the new scope pictures after some changes that the other guys suggested. If you think that i need to change the number of turns i will make it smile
The top picture is with 2 ICs and the bottom is with 4 (two in paralel ). Shoud i use 4 or could stick to 2 ???
1191319942 931 FT31805 Pic 4350
1191319942 931 FT31805 Pic 4349
Bauerb2
Tue Oct 02 2007, 11:08AM
as far as fall/rise times go in both of those waveforms, i think you'll be fine with two. the rise times are a 'little' sluggish by my view of the 2 IC waveform, but if you could, when you start up your coil at low power, try first with 2 then with 4 to see which one performs better. that's what i'd do.
Dr. H.
Tue Oct 02 2007, 11:26AM
Should i try reducing the number of windings on the gtd ? How this will change the waveform ?
Bauerb2
Tue Oct 02 2007, 07:59PM
as you add more turns to the gdt, the waveform starts to look more like a sine wave rather than a square wave. less turns, as i just tested right now (6 turns) , shows the waveform has lost structure and looks like small 6V rounded pulses on the scope. the driver IC's heated up incredibly (burnt my finger) in seconds. this was tested with 2 tc4420's with halfbridge irfp460's and then tested again with a full bridge of 460's. each mosfet has a 10 ohm gate resistor.
it seems i am having some insane trouble with my gdt, i can never get a clean signal. it could be the fact im trying to drive a full bridge with one gdt with one primary, and only 2 driver ic (6 amp each). hehe perhaps, but i dont have 2 similar toroid inductors to use... oh well
wish you luck
-andrew
Dr. H.
Tue Oct 02 2007, 10:04PM
Hi Bauerb2 i actually tried reducing the winding on the gdt. I am now using only 7 turns (compared to the initial 15) and the waveform become litle bit better and the driver chips are running cooler, much cooler than before. I also reduced the gtd decoupling capacitor to 470nF and that improved the waveform further (strangely, any one for explanation ??? ) Tommorow morning i will post the scope traces )
