  • Guests: 24
hvguy (41)
thehappyelectron (14)
Justin (2024)
05/15 Linas (34)
05/15 Toasty (29)
05/16 kg7bz (68)
Cyanoacrilate Glue + Heat = OK?
Sat Aug 25 2007, 02:51PM
Aw, bjorn, please.. Blackplasma is nice, don't flame him.
BP: what's the thing on upper board?
Regarding cyanoacrylate glue.. Yeah, it's very nasty when it gets hot, cured or uncured. From medical use of cyanoacrylate i imagine it is probably not very harmful (deposits into inert solid in lungs) but I don't want to try that theory out.
You can put a fan to blow the fumes off but the it contaminates the whole room. (Bad in summer with AC on).
It also breaks down with heat. It probably won't under a PCB, but too much heat causes it to crack and bubble.
You can tin and then use hot air gun or propane torch to carefully solder the 'traces'.
Or use some other kind of glue, maybe some kind of heat-curing epoxy (The PCB if epoxied fiberglass, after all).
Bjørn
Sat Aug 25 2007, 03:21PM
It is in no way a flame or critisism, just an explanation. As I said I respect that sort of construction more than any other construction that puts looks before functionality.
I have also made worse things than that.
1188055298 27 FT30299 Oscillator
ragnar
Sun Aug 26 2007, 12:20AM
Thanks for pointing out my mess, Andrew and Bjørn -- often in my ignorance / disorganisation I glue the pads down all too quickly (or don't use any pads at all), and rush to get something working.
I will admit, Manhattan-style construction certainly makes debugging easy -- none of the dust-between-tracks risk and crap associated with veroboard / donutboard.
I'm making a concerted effort from now on to make my circuits neater, smaller, and prettier.
Marko, that was a push/pull converter.
Bjørn
Sun Aug 26 2007, 04:04AM
Putting down a grid pattern on the base will probably make it easier to get everything lined up.
Sun Aug 26 2007, 09:04AM
I'm with BP. When people see dead bug prototypes I've built, they think I am on meth, but when they figure out how the circuit works and what it does, they realise it was actually magic mushrooms wink
