  • Guests: 22
Dalus (34)
Kizmo (37)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Iron toroid? [It works]
Thu Aug 16 2007, 05:34PM
Induction to the toroid is a don't care, the fields just don't reach that far.
Ive had aluminum (foil tape) toroids get so hot i didnt want to touch them The secondary coil has a B-field too, Terry.
Kizmo
Tue Oct 16 2007, 12:31PM
I made iron toroid as well for my tabletop sgtc :)
http://xs320.xs.to/xs320/07422/sovitusta.jpg
That pipe is same stuff they use @ bombardier for exhaust manifolds of Lynx and Skidoo four-stroke engines
Tue Oct 16 2007, 12:37PM
Kizmo wrote ...
Looks really nice, but that's a tabletop coil? :-o how big is it?
BTW, I can see a micro black hole in your picture.
Kizmo
Tue Oct 16 2007, 12:55PM
Secondary is about 280mm tall. That is really small coil compared my 8"
That black hole used to be motorcycle license plate :)
Fessenden
Wed Oct 17 2007, 01:26AM
Fessenden Registered Member #687 Joined: Mon May 07 2007, 02:21AM
Are these bends you speak of really iron? I have seen some similar exhaust bends in steel, but never iron. What is the wall thickness of these iron bends?
Also, did you have much trouble soldering these? I know iron is difficult enough to weld, but solder? Seems like it would be very difficult to get it clean enough for a strong bond. I have no doubt you could silver solder similar steel bends with good results.
