  • Guests: 23
AlexRU73 (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
Coating?
Fri Jun 22 2007, 07:42PM
Acrylic spay varnish/laquer has acetone in it,
so anything attacked by acetone is not suitable.
e.g. Acrylic/PMMA, pvc etc.
So do a test before you use it - may not be suitable for all situations.
I found this out when looking for a clear varnish for my acrylic-former TC secondary,
I thought acrylic varnish would be perfect! cry
Fri Jun 22 2007, 08:31PM
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
Good point. I've always applied any spray coating with a strong solvent in very thing coatings at first to protect the underlying surface. ... you can coat Styrofoam if you coat thin enough :)
