  • Guests: 27
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
The molecular force of water expansion
Bored Chemist
Thu Jun 21 2007, 10:42AM
The idea of ice melting under skaters is a myth.
The effect of pressure on freezing point is only about a hundredth of a degree per atmosphere. With something like a couple of hundred pounds of skater on a blade a tenth of an inch thick and a foot long the melting point would only rise by about a quarter of a degree. So unless the ice was between 0 and -0.25 C to begin with it wouldn't melt. It's perfectly possible to skate at 20 below. At that temperature the ice would only melt if the pressure were something like 2000 atmospheres or 30000PSI. I dont think that skates would get anything like that pressure.
atomicthumbs
Mon Nov 05 2007, 09:17PM
atomicthumbs Registered Member #498 Joined: Sun Nov 19 2006, 06:00PM
Well, way back when (around the 30s or 40s), some scientist filled a 4-inch-thick bombshell with water, screwed on the cap, and left it outside in the snow for a night.
He came back in the morning and the thing had a nice neat crack all the way around.
Bored Chemist
Tue Nov 06 2007, 06:49AM
Bomb shells are designed to break.
Tue Nov 06 2007, 02:01PM
Bored Chemist wrote ...
.. on a blade a tenth of an inch thick ...
Do you really think the blade is so thick? I'd say you're off by a factor of 10 at least.
Bjørn
Tue Nov 06 2007, 06:25PM
Some sports have a minimum width of 2.9 mm in the safety regulations and they work fine. A chair sledge has a much wider blade and it works fine too, both on ice and snow.
The rubbing action is probably much more important than the pressure itself.
Electroholic
Tue Nov 06 2007, 07:33PM
and the ice isn't not perfectly flat.
Smlizz
Tue Nov 06 2007, 08:08PM
Smlizz Registered Member #129 Joined: Fri Feb 10 2006, 07:55PM
Here is a video of water in a cast iron shell in a dry ice bath. link
Shaun
Tue Nov 13 2007, 02:32AM
That video is crazy..really puts things in perspective
Now we need a galv iron pipe and a vat of LN2!
Pete
Wed Nov 14 2007, 12:33AM
Pete Registered Member #106 Joined: Thu Feb 09 2006, 09:39PM
goood lord... That's is a sufficient video. I will ALWAYS put proper amounts of antifreeze in my radiator.
rp181
Wed Nov 28 2007, 03:33AM
just speculating, i wonder if that force could be used to get energy from piezo electric materials? i dont know how much those give though
