  • Guests: 28
kg7bz (68)
steve516 (31)
05/17 Finn Hammer (72)
05/17 Blue Adept (43)
05/17 Nickel (68)
Class E SSTC problems
Terry Fritz
Sat Apr 28 2007, 12:40AM
Hi,
Here is a spice program for the "right price" amazed
We used to tune the driver side to the FET too with RLC circuits instead of resistors to get lots of low loss current drive at 13.56MHz to the FET gate.
I would give some patents, but Link2 is AFU for "patent search" links at the moment...
Terry
Ken M.
Sat Apr 28 2007, 12:47AM
I found that if you don't mind NOT having the adjustable duty cycle just wire the R2 and R3 block with a sing pot with no diodes and it should work. Also as a side question but somewhat relevant, what would be the MAX voltage applied to the fet, on a circuit like this, and would adding a Cap in paralel to the primary do any good as well as keeping the cap across the D\S of the fet?
ragnar
Sat Apr 28 2007, 02:38AM
If you have a proper flywheel / output network connecting the primary, there are many variables you can alter:
Cshunt
Cload (primary)
Cseries (flywheel)
Lseries (flywheel)
Lload (primary)
And then there's coupling. You really need to play around.
Andrew L.
Sat Apr 28 2007, 08:32AM
Andrew L. Registered Member #515 Joined: Sun Feb 11 2007, 02:06PM
For now I'll have to put the project on hold because I ran out gate driver chips.
