  • Guests: 11
cbfull (52)
Steve Ward (39)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
Diodes dying on can crusher
Fusion
Thu Feb 15 2007, 12:32PM
Fusion Registered Member #354 Joined: Thu Mar 30 2006, 10:12AM
1N4007 is rated 1Arms, 1000V and 30Apeak
Diode BY255 gives 3Arms, 1300V and support 200A peak
Resistor must be calculated for:
R>Vmax/Ipeak during discharge
Also R>V/Irms during charge
So if V=9kV and Ipk=200A, R would be >45 ohms.
I would set two resistors: one in positive and another in nagative line in order to isolate both lines in order avoid disconnect wires during discharge.
If you do not change configuration after can crunch you can have great voltage that can be over diode voltage rate, but I think diodes would support them with the resistors smile
Billybobjoe
Fri Feb 16 2007, 02:05AM
Billybobjoe Registered Member #396 Joined: Wed Apr 19 2006, 12:55AM
Fusion wrote ...
Thanks!! Those BY255's will simplify things, now I'll have to see what kind of HV resistors I can find (the thread above this one might be useful).
