  • Guests: 15
Vaxian (17)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
400 Joule exploding wire problem
Dr. Shark
Mon Feb 12 2007, 06:18PM
Sorry to rain your parade, but your numbers seem _very_ optimistic. Extracting 50kA from 300V implies that the impedance of the circuit is Z=V/I= 6mOhm. That is about the resistance of 30cm of heavy hook-up wire, without any connections to it.
Worse yet, at your postulated rise time of 1us, which corresponds to a frequency f=1MHz, the maximum inductance in the circuit is limited to L=Z/f = 6nH. This is the inductance of 1cm of wire!!
I am curious how you came up with that number, though.
Fusion
Mon Feb 12 2007, 08:36PM
Fusion Registered Member #354 Joined: Thu Mar 30 2006, 10:12AM
Joe, I did not use any wire, I use thick and short bars. Your asumption is partially pretty good: I used a 1 cm wire. Caps, Bars and switch impedance 3600 microohms (measured), the other impedance was wire one
I used aluminium bars, if copper were used I would had a half of it smile
R=r*L/A
L=length and A=area in meters and square meters
Where r is the resistance that is 1.678E-8 ohm*m for copper and 2.62 e-8 ohm*m aluminium
It is very difficult find big amount of 330uF 400V cheap caps, isnt it?
teravolt
Tue Feb 13 2007, 03:40AM
try a paperclip or 22awg wire for your brake wire and copper tubing or welding wire with a automotive starter solinoid in series.
