  • Guests: 24
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
the best way to stack flyback transformers secondaries?
jpsmith123
Thu Sept 26 2019, 12:41AM
father dest wrote ...
jpsmith123 wrote ...
If you use a big ferrite core
BTW check out this power supply:
that's all great and such, but, the question of this topic was "can you help me a little bit with flyback transformers? / maybe you know the best way to stack transformers?"
it wasn't about how to build high voltage supply per se, or how to build it in a proper way, etc.
it's just about those 4 flybacks, and nothing more, like "gamma rays" for example, LMAO.
I'm sorry; I took the liberty to offer unsolicited advice based on what I might do in that situation.
Because you said: "i think primaries are acting like directly connected to the ground through transistors of the half bridge and mains..."; and because I cannot see the subject transformers and therefore do not know any details of their design and construction, I suggested an isolation transformer as a "holistic" approach to solving the problem. For a person with your knowledge and resources, I thought it was a reasonable suggestion.
Fri Sept 27 2019, 12:15AM
Im bowing out, No need to take part in Gamma rays.
Plasma
Fri Sept 27 2019, 06:59AM
Supposable that can go through 2meters of concrete, and portable too, heck 5MV is easy but if what you ask and plan to do...
Plasma
Sun Oct 13 2019, 04:32AM
Its with NST just replace that with flyback, that picture should get 120kV at 20mA output
With two 15kV 60mA nst, if you don't mind lower current, add a stage to the multiple for more volts.
172548
father dest
Sun Oct 13 2019, 06:24PM
father dest Registered Member #54795 Joined: Mon Apr 06 2015, 11:55AM
so now i need 4 invertors instead of 1? i mean - anybody can stack up battery powered anything, coz such things are isolated from each other per se.
so this answer has nothing to do with my question, again : )
Plasma
Sun Oct 13 2019, 06:49PM
What about inverter to 4 1:1 ferrites then partellel them to the primary of the flyback.
Just have 150kV cable for the 1:1
If you only want 1 ferrite just have 4:1*(4)
father dest
Mon Oct 14 2019, 06:31PM
this suggestion is on previous page - written by "jpsmith123 Tue Sep 24 2019, 03:01PM".
and my answer to it is on the same page too : )
