  • Guests: 19
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
personnal X Ray machine
Thu Feb 14 2019, 06:28AM
Yes, this is the same problem I had.
Interesting idea: what about using a linear device like an LED array? Calibrate elsewhere and then measure it using optical fibre eg TOSLINK cable. Known length of cable should be pretty accurate.
Thu Feb 14 2019, 12:12PM
I don't understand your contribution, Andre - have you by chance posted it in the wrong thread? :)
Fri Feb 15 2019, 04:59AM
This was to do with monitoring voltage and current remotely.
paulj
Fri Feb 15 2019, 06:37AM
paulj Registered Member #59353 Joined: Sun Apr 17 2016, 02:08PM
the idea of optical fiber is interesting, but for economic reasons, I will be content with vintage analog voltmeter with a simple resistance voltage divider and transmit coaxial cable.
Fri Feb 15 2019, 02:01PM
paulj wrote ...
Take care that you do not have more current going into your voltage divider than into your tube! When your power supply can supply only a few milliamps this can be a serious issue!
In practice, you may find that the current drawn by the voltage divider has the effect of pulling down the voltage available to the anode, so do your Ohms Law calculations carefully before deciding what to do! :)
paulj
Fri Feb 15 2019, 03:51PM
I take notes:)
paulj
Wed Feb 27 2019, 07:57PM
first test with flyback transformer.
johnf
Thu Feb 28 2019, 05:46AM
Ho boy
I hope you were no where near that
uSv/hr is not the correct range to be on uSv/min or uSv /sec would be much better --read quicker to a determination. I see that the output was still going up as you turned it off
CAREFUL
You do not want a suntan from that!!!
Thu Feb 28 2019, 06:37AM
Indeed. Been there, done that. Also low energy X-rays are even more damaging.
There is a good reason why the window on some commercial tubes is made from beryllium, it is to block the useless X-rays below 9keV and changing the window eg for tungsten changes the pass energy.
paulj
Thu Feb 28 2019, 07:11AM
oh yes, the translation!
I am 5 meters behind a block wall, and the opposite of the radioactive beam.
