  • Guests: 14
Vaxian (17)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
Legal aspects of the broadcast power
Fri Jun 22 2018, 08:35AM
Can you operate the equipment in a faraday shield ?
A metal-skinned building etc.
You would not be prosecuted if your intention is to avoid broadcasting power / causing interference.
you may be shut down
IF your shielding is inadequate AND you are located ;)
IF your intention is to broadcast power then get a license.
P.S. Tthere are many more monitors than broadcasters,
so the absence of signals does not mean that no one is listening.
Plasma
Sat Jun 30 2018, 11:42AM
There is Al mesh for screen doors I could use, I'm just testing the things at the moment, it will be 1.56mhz so I can notice it on a pixy radio, we're it goes from there, there is a lot to do.
I think the shielding option is the best way.
