  • Guests: 12
cbfull (52)
Steve Ward (39)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
Static electricity detector
Thu Mar 01 2018, 12:57PM
I agree with adding gate-source resistors, start with the highest value that you can find, e.g. 33 MOhm.
Lower resistance = greater stability
Higher resistance = greater sensitivity
Don't make it too stable or it will not detect the smaller ghosts or higher flying UFOs tongue .
P.S. gate-ground is more common and useful than gate-source,
as it allows more stable source-ground voltage - hence stable bias, assuming that you are using a source resistor,
if you do not use a source resistor (typ 100R to 1kR) the drain current will drift a lot with temperature..
Hazmatt_(The Underdog)
Sat Mar 03 2018, 04:44PM
I can't see your vid, but I was working on this years ago and the main problem I had was the gates stayed charged too.
I think I got around this by using a square wave to power the JFET, I say that because I never committed to a design, but give that a try too and see if that will work, I can't remember if it did.
