  • Guests: 20
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
"LightningStorm" vacuum tube Tesla coil project
Sat Aug 06 2016, 08:09PM
jaw-dropping !
fantastic
you must have very considerate (or terrified) neighbours :)
off now to look again,
thanks for sharing.
Dr. H.
Sun Aug 07 2016, 05:37AM
Hi guys,
Mads - as far as I can see - he is using the thyratron just as a normal triac (both implemented as cathode modulation) or I missed something - this is why I asked.
P.S. I like it more with the thyratron tongue
Avenger
Sun Aug 07 2016, 04:55PM
Avenger Registered Member #1275 Joined: Wed Jan 30 2008, 09:33AM
Dr. H. wrote ...
Exactly. I use thyratron as a triac (installed in the cathode circuit).
And yes, it looks more cool)
Avenger
Sat Jul 01 2017, 09:23PM
Frames of both units are made. Generator unit and power supply unit. Frames are welded from 4mm steel. Both frames are equipped with wheels for comfortable movement.
1498944175 1275 FT177486 Img 1744
1498944175 1275 FT177486 Img 1746
1498944175 1275 FT177486 Img 1814
1498944175 1275 FT177486 Img 1815
teravolt
Mon Jul 03 2017, 03:30AM
it is great you plan to make it permanent. I also have one GU-39B-1 have you tried modulating the grid? At some point I would like to do this project. However I don't want to do the standard Armstrong oscillator but modulate the grid with a h-bridge that is fed by the feed back coil
Avenger
Mon Jul 03 2017, 10:44AM
No, I have not tried modulating the tube on a grid. The standard VTTC scheme is chosen because of its simplicity. In the meantime, I began to estimate out the layout of the circuit elements.
1499078653 1275 FT177486 Img 1816
1499078653 1275 FT177486 Img 1817
Mon Jul 03 2017, 05:31PM
Your VTTC is a magnificent piece of work. A pleasure to behold.
The new steel carts are icing on the cake. Have you already picked a color of paint for them?
Avenger
Tue Jul 04 2017, 05:32PM
klugesmith wrote ...
Black. Only black color)
Avenger
Wed Jul 12 2017, 08:10AM
The case of the generator unit is complete
1499847017 1275 FT177486 Img 1819
Avenger
Wed Feb 21 2018, 05:01PM
Hi! I continue to assemble the generator unit. The filament circuit and the cathode bypass battery are mounted. A current transformer is installed in the filament circuit to measure the heating current. The circuit was successfully checked.
1519232338 1275 FT177486 Img 3736
1519232338 1275 FT177486 Img 3735
1519232338 1275 FT177486 Img 3731
