Registered Member #162
I'm not sure exactly what you are constructing but with Class-E (or any resonant circuits) if you fix your clock frequency then every other frequency dependant circuit will need to be tuned to the clock. It will be easier if you have a variable frequency clock which would allow 'tuning' by varying the clock frequency rather than adjusting capacitance or inductance at least for one tuned circuit.
I also doubt that a fixed frequency is best because tuned circuits vary their resonant frequency when loads/environment changes. So, Is there a reason to operate at exactly 4 MHz ? How accurate and stable do you NEED the frequency to be ?
I would go for a simple variable frequency oscillator and an accurate frequency meter (or estimate frequency from your oscilloscope) or something like this digital sig.gen./freq.counter
many microcontrollers used to operate at 4 MHz - masses of info on the web the 5v crystal oscillator that I linked to just needs 0v and +5v, and the output will drive the gate driver ic input directly. I would not add any protection as the cost of an XTO on eBay makes it not worth the complication e.g. (look for TTL or HCMOS'output to be safe, some crystal oscilllators give a distorted sinewave of about 1v)
Registered Member #55219
klugesmith wrote ...
jdub's circuit is for using a bare 2-terminal crystal (passive component). Change the crystal to change the frequency. Sulaiman pointed to some crystal oscillator components, which are easier to use. Connect appropriate power voltage (3.3 or 5 volts) and get a corresponding logic signal out. In both cases the frequency is fixed. Worst case frequency error of +/- 100 ppm (0.01%) is a pretty loose tolerance for crystal controlled oscillators.
Your 74LS624 is a voltage controlled oscillator chip. No crystal is involved, and you can tune the frequency over a substantial range. How are you planning to measure the frequency, if you don't have an oscilloscope? You could divide it down into the audible range (e.g. with CD4040 or CD4060) and listen with headphones or a small loudspeaker. Or adapt an old auto service dwellmeter/tachometer, which I could send you for cost of postage.
It's time you learned a little about logic IC's. Jump on in; they don't bite. Get a plug-in breadboard to play with -- apparently as popular now as they were decades ago. There are other forums to learn at.
Cool, I am using the 4mh xtal and 7493ic as a divider -outputs: A=fo/2, B fo/4, C=fo/8, D = fo/16 Which should give me a 2mhz, 1mhz, 500khz, 250khz clocks to choose from..
Registered Member #3114
Sulaiman wrote ...
Perfect, thats exactly the information I was looking for. I am working on a class e tesla coil. I can check the frequency witht he scope no problem. I want to drive the FET's like this guy is From reading the site he doesn't seem to have a class e drive arrangement, just the X Mhz signal feeding the IXDD614 MOSFET driver which outputs the square wave to the FQA11N90 gate. With that setup I would need the GDT's or to match impedance,further more i wouldn't need the classe e mosfet drive stage before the final class e circuit like Erik has.. Or am I missing something.
Its hard enough for me to grasp all this without the added effect of high frequency and resonance messing with everything.
ZakWolf wrote ...
I'm with ya man... The matching networks are a pain, and right when I think it's making sense, I go and confuse myself again.. Then again I may be going backwards in my process .. Adapting to what I have available.. My math is pretty good, but part reduction and circuit simplicity still trouble me.
Registered Member #3379
Reaching has a good simple 4Mhz class E audio modulated coil which I have built. Works very well. You don't have to add the audio modulation part if you don't want to. Claude.
So I lashed up a circuit with a 3.6Mhz crystal I have and used a 74HC14N Hex Schmitt-Trigger. Flowed this schematic... I used random values 500k pot (Fres adjust) for R1, 10k for R2 and 240pF for C1&C2
Scope Shot: The yellow trace is the Xtal ( 8 MHz is not accurate it was jumping all over the place but was most commonly at aroun 2.2 MHz) Blue: square wave output at ~6v
Looks like bad ringing.. stable up to about 4MHz limited by crystal probably... LM7805 with heavy filtering supplying Vcc. How to I go about calculating correct values? This produces square wave into the 100kHz range and up so if I get a high rated Xtal I should be able to achieve a 4Mhz zignal
How do I reduce the ringing ?
Edit: didnt have my POT in the right place, added the 1Mohm resistor across pins 1 and 2. Adjusting cap values I can get a range of different frequency's but the ringing is still an issue. I was able to achieve higher then 4Mhz with fixing my build
Registered Member #2099
Hi Zak. Nothing wrong with plugging in components at hand to see what happens. But that circuit, with your reported values of R and C, is not a crystal oscillator. It's a tunable schmitt-trigger oscillator that would run, probably better, if you omit the crystal. R1 and the C on left side determine the frequency. To shift the tuning range to higher frequencies, put a smaller C over there (or both of your 240-pF C's in series).
The schematic image you posted tells how to choose values for a better shot at making it a _crystal_ oscillator. In that mode it would oscillate at 3.6 MHz +/- 0.01%, a frequency insensitive to modest changes in R and C values. The table in the schematic might give the impression that C and R2 determine the frequency. No! Frequency is set by the nominal value marked on the crystal package. Then you choose C and R2 values from the table to make a functional oscillator. You would have to extrapolate to pick likely values to work with a 3.6 MHz crystal. Or use values posted elsewhere in this thread for use with 4 MHz crystals (close enough). Good luck!
[edit] the ringing in your scope picture is probably an artifact of power and ground routing to the oscillator components and/or the scope probe. Can we see a picture? What's the nominal bandwidth (not the sampling rate) of the scope? Does it have a menu option to artificially reduce the bandwidth?
Awesome, Thanks for that I will try in a min. to omit the Crystal. My scope is a rigol DS1054z only had it a couple weeks so Im still learning how to use it
Sorry for the double post but I wanted to add a new scope picture. A bit jittery
This is the square wave without the crystal. Using 120pF and a 1Mohm pot to adjust frequency. I switched my probe to 1x and scope as well and that seem to have cleaned up the input. Was it looking so messy before because of the 10x setting? I know there is a capacitance in the probe at higher ranges right ?
