Registered Member #54278
I was a bit brief. What really needs to be measured is the frequency of the LC circuit. It can either be calculated--not very accurate in the real world, OR the time between zero-crossings measured and frequency derived from that: f=1/t.
Registered Member #518
I used a online calculator to find resonance... How can I optimize capacitance too? I used a value that someone on youtube used... Each capacitor value will require about 40 experiments to get data ...
WOW--is that meter right?? My thought..."I wish I could get that kind of L in air-core coils" Maybe the "low batt" is having an effect. can you give a good value of the diameter of the coil and exactly how many turns on the coil connected to the meter--that would help. It is air-core for sure, right?
The formula for the frequency of an LC resonance circuit is f(Hz)=1/[2*pi sqrt(LC)]. Can you solve this formula for, say, "L" by hand--We are so dependent on machines now.
edit: Just had a thought--your meter could be broken, or simply putting "mH" for "uH" Do you have a second way to measure this coil OR a coil of KNOWN "mH's"?
Signification wrote ...
Here I posted all the data, including coil parameters..
Knowing the inductance value isn't important to me, my tests are based on empirical data. Distance at calculator rest/scramble, using different coils. When I did my second test, I tried to use direct connections instead of using long wires. This made data for low turn coils more accurate. I also used the same coil diameter for all the coils, only varying the number of turns. Ignore the first set of data.
I am very familiar with the false HIGH VOLTAGE claims of those ebay modules--I just saw a module rated at 1,000,000 V today! it's like the outrageous claims on the stun gun's millions of voltages--I guess a way to measure it yourself must be found to know what is going on--also the output waveform is strange.
--seems we were writing replies simultaneously here!
