  • Guests: 29
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
How cruical is a VARIAC?
Hazmatt_(The Underdog)
Sun Sept 20 2015, 03:10PM
Something else to point out here, it uses a carbon brush contact.
Exceeding the power handling by a large amount causes that brush to get very hot and burn the winding, and the brush, so I would recommend exceeding that rating only conservatively and for brief periods of time.
Sun Sept 20 2015, 07:38PM
See page 1 for a overload curve, %overload vs. time Link2,%20M5%20,%20M10,%20and%20M20%20Variac% 20Autotransformers.pdf
Hydron
Mon Sept 21 2015, 11:29PM
Get the coil up and running with the 8A variac, it'll do fine for low power testing.
Assuming it's a DRSSTC all you need to get higher power later is to build up a phase controlled rectifier - A Dual SCR brick (or maybe some discrete SCRs) is all you need for oodles of power. I think steve conner's site has a schematic floating round using a couple of 555s.
Bigger Variacs do occasionally pop up on trademe, but they're not common. I got my 15A one for $150 NZD, which is a bargain (though it doesn't have a proper dial).
Could probably get a SCR brick on ebay - mine are unfortunately packed away back home (I'm in the UK right now), otherwise I'd be happy to give you a couple.
dexter
Tue Sept 22 2015, 05:55AM
Hydron wrote ...
i built that using a 91A dual thyristor module and it works ok
the main advantage of using a phase controlled rectifier is that it can also work as a doubler while still maintaining thr "variac"function
nzoomed
Tue Sept 22 2015, 06:16AM
Hydron wrote ...
If i did this would it allow me to run my coil at higher output without having to get a higher rated wall outlet installed?
GrantX
Tue Sept 22 2015, 06:39AM
I don't think you'll have to upgrade your wall outlet, unless it's running continuously. I double checked, and we use the same outlet design as NZ. I regularly pull >20A from the 10A outlets in my workshop (usually the MIG welder). They're wired with 2.5mm^2 cable and 20A breakers, so nothing generates any heat at all. I've pulled more than 50A from the 15A outlet in short bursts of a few seconds, and invariably the breaker trips long before the outlet gets warm.
nzoomed
Tue Sept 22 2015, 10:41AM
GrantX wrote ...
OK thats sweet, ill just look out for a bigger variac for operating at full power 20A would be its absolute max
GrantX
Tue Sept 22 2015, 12:16PM
nzoomed wrote ...
Yeah, the winding and carbon brush will likely see more stress than the outlet. Power outlets seem to endure lots of rough treatment without problems. The breaker should be sized correctly to protect the house wiring, not the outlet itself. It's a good idea to check the condition and size of the wiring behind the outlet before unleashing abuse beyond it's ratings.
Wed Sept 23 2015, 12:47AM
HAHAHAH yea, I pulled 220A from a 30A breaker for 3 seconds.
We had a 3180V transformer we used to run as a Jachob's ladder, boy did that thing pull a ton of current!
nzoomed
Wed Sept 23 2015, 01:07AM
WOW, didnt think that was possible lol. I have a 3000W light bulb that would trip the breaker after a few seconds, but that was at my old home.
