  • Guests: 23
GODSFUSION (37)
Zajcek (37)
ElectroDog (33)
sportcoupe (56)
04/30 BlakFyre (36)
04/30 SENTRY (31)
05/01 Shaun (34)
TDK Ceramic "Doorknob" Capacitors For a Tesla Coil
nzoomed
Tue Sept 22 2015, 08:53PM
GrantX wrote ...
nzoomed wrote ...
Does anyone know much about these russian ceramic caps on ebay?
There sees to be tons of old stock doorknob caps on ebay that were made in the USSR, but i dont know how reliable they are, but they also seem to be in rather low values, i need to make a 225nf bank for my MMC.
If I recall correctly, the ones marked "K15У-1" are low loss RF ceramics, and seem to be very popular in VTTC's. I've got a few 10kV 2200pF and 8kV 3300pF examples laying around, but I haven't yet used them as tank capacitors. They seem abundant and cheap, but you'll need a huge pile to reach 225nF.
This site lists some of the common Russian capacitor codes, which makes searching ebay a lot easier: Link2
Thanks ill check that out.
Im building a DRSSTC and am looking for alternative caps, especially now that i would like to up my voltage rating a little, i thik 8KV is a bit on the low side.
Hydron
Tue Sept 22 2015, 11:42PM
As I mentioned in another thread I still recommend looking at using the Aerovox RBPS snubbers (2uF 1kV) - for example 34 (2 parallel strings of 17) gives 235nF at 17kV. Mine ended up about 5 NZD each inc all shipping costs.
nzoomed
Wed Sept 23 2015, 01:08AM
Hydron wrote ...
Yes i was looking at that, but they are going to cost me more than the CDE series caps.
jpsmith123
Wed Sept 23 2015, 06:22PM
What about one of the metallized polypropylene capacitors from this place:
(I was looking at that 20kv 0.1uF cap for my own possible use, but they're not forthcoming with the specs. for some reason. At a price of $106 USD, it might be a good deal, but without any idea of the peak and rms current rating, max. dv/dt, and inductance, I can't use it).
nzoomed
Wed Sept 23 2015, 10:11PM
jpsmith123 wrote ...
Those do look alright, so ill keep those in mind.
Ive just heard back from a local supplier who has a large amount of snubber caps at a cheap price, they are 4.7uf rated at around 750v each, so 21 in series will give me what i need for my bank rated at around 16KV!
I wonder if its worth using less caps to get a higher capacity MMC?
I believe people like higher values is there any preferred value people like?
It seems people use 375nf quite a bit on their coils.
nzoomed
Sun Sept 27 2015, 08:54PM
Ive just managed to score these snubber caps for only $2 NZD each!
They are rated at 770VDC so should give me a 225nf bank rated at 16KV if i have 21 in series.
I see their AC rating is only 440V, but it will still be rated at almost 10KV at the AC rating, im not sure what is most important in a tesla coil, but i think i will be sweet.
20150928 093806 1
Sun Sept 27 2015, 09:38PM
I think the general concensus is to have several strings, and distribute the current evenly between them. How much current can you put through those leads before they get hot and the resistance rises?
nzoomed
Mon Sept 28 2015, 02:15AM
Ash Small wrote ...
Yes i didnt think much about that at the time, this means i may need more capacitors, how many amps would i expect to go across these caps? My bus voltage is about 680V.
I saw loneoceans had all his caps in series but they are larger doorknob caps, i thought these had heavier terminals on these caps, so i didnt think much about it.
Mon Sept 28 2015, 06:07AM
nzoomed wrote ...
Ash Small wrote ...
I do not think you should expect more than 5-10 Arms from these capacitors, peak current is hard to guess, if you know the dv/dt rating it can be calculated.
Do you know about my MMC calculator? Link2
It is a good tool to find out if your MMC can withstand the load/abuse seen in a DRSSTC.
nzoomed
Mon Sept 28 2015, 11:06AM
Mads Barnkob wrote ...
nzoomed wrote ...
Ash Small wrote ...
Ill have a play around with it, i was unsure if it was much use to me since my caps are not on that list and i am unsure of their capacity, what i do know is that the supplier told me a string of 21 would handle 200A easily, I know they far exceed that of a CDE 942 series cap.
