  • Guests: 29
Shaun (34)
Spedy (30)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
Modern AC Flyback Transformers
Tue Sept 02 2014, 03:00PM
Fiddy, do these have an airgap? When the 13.2 kV was quoted, which mode was it in?
Tue Sept 02 2014, 03:04PM
Those look pretty nice, very similar to the ones which are used in cheep co2 laser power supplies, which are good for a good kw continuous output power. If you have the option, I would personally rather see one with a little heavier gauge wire on the secondary, although 28awg should still be good for a few hundred mA before it melts down.
At $40 a piece I won't buy 10 but might be in for a few of them, sure beats winding my own Link2
Dago
Wed Sept 03 2014, 06:20AM
I'm also interested in maybe a couple of them.
Rod-on
Wed Sept 03 2014, 07:35AM
Rod-on Registered Member #6541 Joined: Sun Sept 09 2012, 05:01AM
I'd like two of them, I'd like to make a couple of plasma globes
Fiddy
Wed Sept 03 2014, 09:43AM
Fiddy Registered Member #8817 Joined: Mon Dec 17 2012, 05:16AM
Awesome ill make a list in the OP and then order at least that many soley depenedent on cost.
Meanwhile, here is the production sample running off a ZVS driver @ 24V
Daedronus
Wed Sept 03 2014, 01:48PM
I would like to see it running off a full bridge at higher voltage, since I'm interested in higher output voltages.
Dragon64
Wed Sept 03 2014, 05:10PM
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
I'd be interested one of these as well. Though I'm unsure if you're willing to ship to Canada (and also how much the shipping fee will be).
hen918
Wed Sept 03 2014, 05:19PM
I defiantly want one (or two)!
Wed Sept 03 2014, 06:43PM
Neat stuff.
I will probably get myself a projection-TV size transformer with positive and negative CW-triplers built in + AC output sometime.
Mind telling who you buy from? I have some special flybacks here but I haven't made a driver yet.
Fiddy
Mon Sept 08 2014, 06:05AM
Im thinking of getting 20 made, im discussing price with the manufacture at the moment. Im getting them for $25USD for 20 units, then there is shipping for almost 25kg which raises the price substantially.
