  • Guests: 23
Dalus (34)
Kizmo (37)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Small CNC Mill - mechanics finished
Dr. H.
Sat Dec 14 2013, 06:52PM
Hi guys
not everything is going to plan ... angry A cheap chinese transformer went crazy and burnt some of the electronics in the old mill... some repairs were needed .... darn it ... Back and running now but with almost a week delay ....
Nice software Carbon Rod, thanks for shearing smile I am planning to play with some 3d printing in the not so near future ... but only plans for now.
Cheers
1387047108 931 FT159100 Img 20131214 124305
Dr. H.
Sun Dec 22 2013, 08:14PM
Hi guys
moving forward on the project - most of the ALU parts have been cut. I will be getting home for Christmas soon so till then I hope to have all parts to start assembling .
Cheers
1387743222 931 FT159100 Img 20131201 160012
1387743222 931 FT159100 Img 20131207 195518
1387743222 931 FT159100 Img 20131206 203430
1387743222 931 FT159100 Img 20131201 200545
Dr. H.
Sat Dec 28 2013, 08:51PM
Hi guys
I am back in the good old big workshop smile . All of the parts are cut - time to start the assembly.
P.S. Hmm I didn't imagine soo many parts wink
Cheers
1388263806 931 FT159100 Dsc 3197
1388263808 931 FT159100 Dsc 3199
1388263808 931 FT159100 Dsc 3200
Dr. H.
Tue Dec 31 2013, 06:03PM
Hi guys
moving forward on the project. The mill is starting to take shape. Cheers and happy new year smile
1388513001 931 FT159100 Dsc 3214
1388513001 931 FT159100 Dsc 3217
1388513001 931 FT159100 Dsc 3212
Shrad
Wed Jan 01 2014, 08:55AM
advice for power supplies...
use server power supplies like IBM or HP power supplies... they deliver 12V or 24V at the 50A level, plus other voltages at useful powers like5V 20A, 3V3 10A or things like this
main thing is they are sturdy, deliver top current without sagging, are reliable and have parameter monitoring through SPI, plus their PFC and almost 90% efficiency for the better ones
the latest I had a look for were 12V 50A supplies plus other voltages (600W total) for 6€ without shipping!
and the form factor is pleasant too... 5*5*30cm :)
Dr. H.
Mon Jan 06 2014, 06:40PM
Hi guys
Shrad - this is a good suggestion. I've spent quite a lot of time looking for a power supply second hand but didn't find anything that worked fine for me and this is why I opted for this one. I've tried a 24V 350W SMPS from a medical equipment but was just too big to fit in the base of the machine. Good idea about the server supplies smile
To update the project - the X and Z are fully complete (except for the servo shaft extender and pulley - hope to make them tomorrow). Those little things sure take forever (end switches, optical sensors, cable guide ...)
I've done some speed tests and it seems the machine will be able to move in the 4000mm/min range witch is really nice cheesey
Cheers smile
1389033363 931 FT159100 Dsc 3262
1389033364 931 FT159100 Dsc 3263
1389033364 931 FT159100 Dsc 3265
1389033364 931 FT159100 Dsc 3268
Dr. H.
Thu Jan 09 2014, 08:28PM
Hi guys
The base is almost finished. One of the trickiest part remains - the protective cover for the guides and scew. Will be fighting with it tomorrow and after that final assembly of the mechanics.
Cheers smile
1389299228 931 FT159100 Dsc 3272
1389299228 931 FT159100 Dsc 3277
1389299228 931 FT159100 Dsc 3282
Thu Jan 09 2014, 09:37PM
That is some top quality do it yourself right there, I am impressed :)
I have some slide bearings for round rods with a flat side for screw mounting to a plate, I saved those for a possible DIY CNC project. There is 12 of them, so I have for xyz. They are around 40mm long and for a Ø20mm rod, (similar type: Link2 ) I fear that a rod only fixed in the ends can vibrate too much compared to a linear that is fixed along the axis with multiple screws, do you think there are stable enough compared to a linear bearing?
Dr. H.
Sun Jan 12 2014, 06:29PM
Hi guys
the mill is mechanically fully complete now smile. Time to start on the electronics.
Hi Mads - thanks for the kind words. Yes those round rails are really prone to bending and vibration. It all depends what you intend to do with the mill, but 20mm is suitable for small travels (and loads). My big mill uses 40mm rails and the travel is about 50cm (full lenght is about 70cm between supports) and it bends really bad. If you want some rigidity and don't want to spend too much money the supported round rails are a relatively good choice. Much better than the unsupported.
Cheers.
1389551344 931 FT159100 Dsc 3293
1389551344 931 FT159100 Dsc 3308
1389551344 931 FT159100 Dsc 3306
1389551344 931 FT159100 Dsc 3315
Wed Jan 22 2014, 09:05PM
Masterful, just masterful build.
is that transformer device with heat sinks in the lower left of the pics, your power supply for this machine?
