  • Guests: 21
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
GDT's for low frequencies
Mon Sept 11 2006, 11:19AM
Type 77 and 78 material will both work fine.
What kind of devices are you running???
Dr. Shark
Mon Sept 11 2006, 04:08PM
Sulaiman wrote ...
The nett result is, core size is INVERSELY proportional to frequency
so a very large core is required at low frequencies.
Just in case you missed this, I'll emphasize that it is a VERY important fact to consider. Even for SSTC frequencys I found that a lot of the cores I tried simply did not have enough crosssection to work without saturating, and I had to use way more turns that people usually suggest here. What is the size of your cores?
Thomas
Mon Sept 11 2006, 08:58PM
Thomas Registered Member #120 Joined: Fri Feb 10 2006, 07:07AM
Oh this is for a flyback h-bridge.
I never knew that the size of the core had a impact on the windings. I never really took this in to concideration. The outer hole is 2.5cm, the inner hole is 1.5cm and the width is 1cm. I have pspice, but I don't understand how to use it yet. I need to read some documentation, however, homework is first still my priority :() Too bad i'm not take any electrical classes this semester.
Tue Sept 12 2006, 08:03AM
OK, so the core is 0.5cm wide by 1cm thick, cross-sectional area = 50 mm2
For most ferrites you can use 0.2T peak an the 5-40 kHz region
so the peak magnetic flux is 0.2T x 50mm2 = 10 x 10-6 Wb (10 uV.s)
At 5 kHz and 50% duty the ON time is 100 us
For 10 V gate drive that's 10V x 100 us = 1 mV.s
So you need 1 mV.s/10 uV.s = 100 turns.
No need for a simulator!
Tue Sept 12 2006, 09:53AM
Technically I think 50 turns should be ok. (In the steady state the flux will swing from -10 to +10 uv.s per each half cycle, not 0 to 10)
I notice Tom said that he already tried a toroid with 100 turns and it didn't work, though. I'm going to guess this is because he just wound two separate windings instead of using the multifilar technique with its much lower leakage inductance. (good luck making a 100 turn 5-filar winding!)
Steve
Sat Sept 16 2006, 01:12PM
5Khz is pretty low frequency for flyback driving!
You'l be in toruble fitting 100 turns on a small core using thick enough wire, and mantaining low enough leakage inductance and resistance!
For 50kHz, steve ward used 10 turns and I frequently use this as experimentally-confirmed orientation point wink
40kHz would probably requirefew more turns on core of same size, but on very small core (5mm^2) you will have trouble fitting everything.
For 5kHz and around, I would use a high-perm iron powder toroid (I guess that from ATX supplies could serve) and hope it would work for up to some 10kHz. It would allow you to use much more fair number of turns. (I need someone to veryfy this as I didn't try it^^)
Wolfram
Fri Sept 22 2006, 03:39PM
How about a high-side FET gate driver chip, for these frequencies they should work fine.
