  • Guests: 15
Adam Munich (30)
Alfredo Texacca (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
flat copper coil...?
Yandersen
Sat Jul 13 2013, 06:48AM
As far as I know Al can not be soldered in an open air due to instantaneous forming of Al2O3. Whatever I tried did not work - joint easily breaks after cooling even if it seems OK.
The only option I see is an electrical welding - connect both pieces of aluminum to the charged cap and make a sparky contact. Do not try it with thin aluminum foil - roll a corner of it to form a thicker chunk.
But I would recommend a mechanical contact - roll a tip of a foil over thick copper wire and clamp it into smg like a steel "U" pressurizing the mesh with plains as hard as possible to destroy oxide inside for better contact and prevent wire from sliding out.
Sat Jul 13 2013, 08:40AM
This video shows how to solder aluminium, using the correct flux and a tin/copper solder.
The notes accompanying the video are here:
Published on 9 Oct 2012
INDOFLUX AX-39. Aluminium Soldering Flux.(external Flux)
Solder To Al Sheet And Bulb Cap.
Can Be Applied in Solder Wire Flux Core. (ALUBOND Product)
Excellent Invention made by R&D Departement.
For :
Aluminium sheet, Light Bulb Cap soldering. Tin Solder Flux for Aluminium.
Using Torch, or By High Watt Solder.
Indonesia product.
ISO 9001-2008, TUV Rheinland, Certified Manufacturer.
Signification
Sat Jan 31 2015, 01:28AM
I toyed with this idea a while back, when, at first glance, I wondered if a single long flat turn (the length of the entire gun) acted as more than a single-turn loop of wire. I concluded that that there was no difference in the number-of-turns variable (N) for foil or wire.
Also, it occurred that the connections to the two wide end terminals of this coil should be such that the current flows 'into' and 'out of' the entire width of the flat ends--perhaps a large-gauge stranded wire "flattened out" and the strands soldered along the width of the copper edge ends. BUT--this may be a little tricky to implement on the 'buried' inner end layer which is somewhat inaccessible and should lie flat along the barrel !!
Has anyone thought about the inherent capacitance in this type of 'inductor'? In fact, it looks more like a (multi-layer cylindrical) capacitor.
hen918
Sat Jan 31 2015, 02:28PM
Signification wrote ...
When the inductance is that low, I don't imagine that the tiny capacitance will make any difference to anything. Think of the milli-farads that you are putting into the coil. The capacitance of the coil will be in the order of pico-farads.
Signification
Sat Jan 31 2015, 10:01PM
...so that is milli-Farads to pico-Farads: a NINE magnitude order ratio of applied to parasitic capacitance...OK !!
