  • Guests: 22
Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
TDU Microwave/Telsa prize
Thu Aug 31 2006, 09:50PM
Yes, depending on luck motor may have a winding with easily removable wire wink
You can use fan motor for gap and use wire from plate rotation motor, and etc..
Thu Aug 31 2006, 09:54PM
All good ideas but now thing about what you have to work with, there arent alot of materials you can use to make the rotary gap, or even a static one for that matter. This is going to be harder then i thought.
Roger
Thu Aug 31 2006, 10:18PM
Roger Registered Member #221 Joined: Mon Feb 20 2006, 05:36PM
Here is an idea for creative cheating. Use something like 240v at 120 cycles per sec. as a power source instead of 120v at 60 cycles per sec. This is assuming that your microwave oven was designed for 120v 60 cps. Correct me if I'm wrong but I'm thinking that if you increase both the input voltage and the line frequency to a MOT you can get higher voltage and more power out of it.
Roger
Thu Aug 31 2006, 10:26PM
TDU didn't define the power source in rules, but it's somehow logical that anything more than mains is considered as a part of coil (otherwise someone couls just bring a MOT stack or something and dumb up everything)
Variac is a more of a tool than a coil part (I would say), like you are allowed to use your soldering iron or multimeter..
Thu Aug 31 2006, 10:53PM
I don't have time to even start to work on something like this, so I will offer my ideas:
Secondary:
Wire-out of the table rotation motor
Former- take the manual (might need to print it off the net unless you found a brand new one wink ) and roll up a page or 2
Top load-big ball of wadded up wire from the motor you took the secondary wire from
Primary:
Wire: Wire- from power cord or other wiring (I am gonna say you only need 1 turn in order to try to use that 1ufd tank cap
Former: the plastic in the front door
Tank cap- the voltage doubler cap (unless there are enough caps on the pcb's to make one)
Spark gap- 2 bolts from the oven sanded to have a conical shape with the fan blowing across it
Power source- the mot (might also want to add in the diode in series with it in case it can't charge the cap fast enough, but wintesla said 1.2uf would be perfect)
If the manual is too far of the stretch for TDU I would recommend you either try to make one out of the plastic on the front door (ala blackplasma style) or if you have one with the digital timer rip the plastic sticker off it and roll it up...
Simon Barsinister
Thu Aug 31 2006, 11:35PM
Simon Barsinister Registered Member #116 Joined: Fri Feb 10 2006, 03:19AM
In my dissection of many u-waves, I found a Amana radar-range that had a seperate filament transformer. That would have yielded plenty of wire for a secondary. So keep your eyes open for a 1980's vintage Amana.
Rich
Avalanche
Thu Aug 31 2006, 11:46PM
I suppose you could wind a flat secondary, totally by hand, on the plate. It would probably take a couple of days cheesey
I might have to enter this now
Tesladownunder
Fri Sept 01 2006, 12:42AM
Roger wrote ...
Here is an idea for creative cheating. Use something like 240v at 120 cycles per sec. as a power source ...
Really this should run on mains only as a variac gives a 10% advantage and real cost in a zero cost project. So I have changed my mind about the variac. You don't need a variac to run a MO anyway.
... wrote ...
Manual is not on, nor is the packing box etc. Just a plain empty MO that you found on a street corner.
Simon Barsinister wrote ...
Rich
I'm not sure that this gives a level playing field or is in the spirit of this competition. The usual domestic MO's seem remarkably similar and fair.
There are several sources of wire in an MO, and I think enough to make it work. I have already started winding my secondary and it is not on anything mentioned yet but is part of the MO that you rarely see.
No-one has really considered the tank cap properly. You are going to have to get your hands dirty - hint.
Peter
Fri Sept 01 2006, 02:02AM
dead my secondary wire snapped. I wonder if there is anything in the microwave that can be used to cover a splice...
Wilson
Fri Sept 01 2006, 05:19AM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
Perhaps make a plate capacitor from the door and the metal sides? ohoh, i'm not sure if this is correct, but i think i recall reading somewhere that the magetron kinda acts like a capacitor?
The fan has lots of good wire...but i guess you'll want to use that for quenching. I think the secondary would be the most challenging....seeing as you have to make ur own former...
btw nik, you could try melting some wire insulation on the broken patch ;) or just strip a thin wire, and use the insulation as a sheath.
