  • Guests: 36
Alfons (36)
Coronafix (51)
AmonRa (44)
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
First Brick Coil - CM200 Half-bridge
Fri May 03 2013, 12:04PM
Beautiful performance!!!
Have you had any primary strikes?
loneoceans
Fri May 03 2013, 02:42PM
Steve Conner wrote ...
Very nice smile do you know what the operating frequency is?
As measured with a signal generator and scope, I'm currently running the coil at just around 106kHz. :) The unloaded secondary Freq0 is about 122kHz, but streamer loading brings the freq0 down and it seems to do very well.
EasternVoltageResearch wrote ...
Thanks! No I haven't had a primary strike. As you can see, the last 'turn' around the primary is a ground strike ring, which it has hit. The brown circle on top of the primary is an acrylic primary cover (haven't taken off the protective paper yet) which should help reduce dust build up and provide a small amount of insulation.
loneoceans
Sun May 12 2013, 03:25PM
Hi everyone! Happy Mother's Day!
I finally wired up my coil and plugged it running 208VAC. Here's the results at 100us on-time, just barely turning open the taps and really running out of space to test it. It's hardly running anywhere near full power. Roughly 200bps, 500Apk.
8731596738 Cac8608421 C D
And another one:
8732485120 50aeddbec6 C D
Enjoy amazed
More to come soon!
Physics Junkie
Sun May 12 2013, 10:48PM
What a little beast that is... well done.
Are you doubling the 208v input?
loneoceans
Sun May 19 2013, 09:10PM
Physics Junkie wrote ...
Yes I do have a voltage doubler since I'm using a half bridge, so it's running something like +-294V across the bridge :)
I also made a short video of it in action!
loneoceans
Thu Jan 22 2015, 07:01PM
Hi everyone,
In case you were following, I hought I would give a update on some tweaks I made just recently to my old DRSSTC 2 after it got moved over from one side of the US to the other side.
Surprisingly, it didn't fall apart in USPS mail! amazed
16015799276 294f5d5fd5 Z
I re-did the wiring and upgraded the drive circuitry to my UD2.7 as well as made a new toroid for it.
Everything still fits in the 1' x 1' square box and I think I even managed to carve out some extra space! I was also invited for a demo at a nearby science fair just as a side show, and the coil worked very reliably over the course of an entire day, playing music and lighting up fluorotubes.
.. from the Nutcracker, just in time for the holiday season.
As always, lots more construction details and photographs on my updated project page here: Link2
